...and another Fox ...
[Closed] ...and another Fox forks service question...
4 Users
Here's the thing, when I gave em their first service I drained out the damper oil and measured the amount- 110ml. According to fox it should have 160ml in? so I put 160ml back in. Now I cant get full travel so it seems 160ml is too much.
Can anybody tell me how flippin much oil sposed to be in a float 140 2009?
Fox site doesn't mention 2009 floats so anywhere else got this info?
...I thankyou.
Posted : 16/04/2009 5:35 pm
[url= http://www.foxracingshox.com/fox_tech_center/owners_manuals/09/Eng/2009_OM_eng.htm ]User Guide[/url]
Is there anything in the user guide, I can't access it from the PC I'm on.
You could give Mojo a ring as they will know for sure.
Posted : 16/04/2009 5:49 pm
Is there a possibility you have put too much oil in the air spring chamber? It would have the same effect.
Posted : 16/04/2009 6:20 pm
Not touched the air chamber so cant be that. Nothing on the fox site about 09 floats I can find so calling mojo could be a good...er call.
Tanks
Posted : 16/04/2009 7:06 pm
Unless you flushed it out - I'd suspect there was some oil still in after draining
try 150ml
Posted : 16/04/2009 7:08 pm
