An age-old problem....
[Closed] An age-old problem... seatpost slippage
15 Users
The seatpost on my Fuel EX just will not stay in place. I'm cranking the QR hard – harder than I've ever done on any of my previous bikes - and it STILL slips. Any ideas for solving this, apart from never sitting my fat arse down? (Aluminium frame and seatpost, by the way.)
Posted : 04/09/2012 8:59 am
Thomson?
Posted : 04/09/2012 9:00 am
No Bontrager. 2011 Rhythm. Nice post. But becoming so very annoying...
Posted : 04/09/2012 9:03 am
used chalk dust in my steel niner with thomson post, does the trick, just need to take it out regularly to stop it seizing
Posted : 04/09/2012 9:04 am
As it's alu-on-alu, I don't need to be too worried about galvanic corrosion... Or maybe I need a new 'post?
Posted : 04/09/2012 9:06 am
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=39481 ]This worked on my road bike [/url]
Posted : 04/09/2012 9:13 am
Try a different clamp and see if it solves the problem, borrow one from a mate to test.
Posted : 04/09/2012 9:15 am
I had this problem too, also on a Gary Fisher (so a Trek really) with a Bonty post. Carbon assembly paste fixed it without needing to buy any new kit. It has gritty bits* in it that help the tube to hold the post without needing too much force, and it has goop* that stops the whole thing seizing up completely.
*technical term
[Edit: yeah, that Ritchey stuff spuddle just linked to should do the trick - you can get better value than that though. I think I got some Finish Line stuff in a sale somewhere.]
Posted : 04/09/2012 9:21 am
My seatpost wasn't slipping, but it was creaking which is the precursor to slipping. Solved it with some carbon assembly paste, tho' the guy at the bike shop said a sprinkling of sand in normal grease would do just as well at a fraction the price!
@spuddle, chakaping, mintimperial and perthmtb: thank you very much indeed. I knew there had to be a sensible answer somewhere...
Posted : 04/09/2012 9:29 am
I'll give this a shot with my Thomson post.
Posted : 04/09/2012 9:41 am
Some seatposts have an anodising finish that's just too shiny - best solution I've found is to knurl it. If you're near Glasgow, pop it in and I'll use my knurling gadget on it...
Posted : 04/09/2012 9:45 am
"pop it in and I'll use my knurling gadget on it..."
there's an offer you don't see every day!
Posted : 04/09/2012 10:29 am
 tomd
If the QR is a bit dirty it can take a lot of force to close it without out it clamping very tight. Have you tried cleaning and putting a wee bit of grease on QR mechanism? I've found that helps for me.
Posted : 04/09/2012 11:24 am
Wet & dry, take the shine off and jobs a good'u n 🙂
Posted : 04/09/2012 11:27 am
 Sam
Carbon assembly paste ftw
Posted : 04/09/2012 11:50 am
 JoeG
If the above don't solve your problem, try a double clamp like [url= http://problemsolversbike.com/products/double_klamp_seatpost_clamp/ ]this[/url] or [url= http://www.feltbicycles.com/USA/2013/Gear/Parts/road/Double-Seatpost-Clamp.aspx ] this.[/url]
Posted : 05/09/2012 4:06 am
Thanks all. I've never had the offer of a "knurling gadget" before... 🙂 Carbon Paste is in the post...
Posted : 05/09/2012 2:44 pm
Do what tomd says too, it makes a huge difference to the clamping force.
Posted : 05/09/2012 2:48 pm
