Right, the rad cage is supposedly meant to improve things on large cassettes by altering the way the upper jockey wheel tracks across the cassette, it supposedly does this by offsetting the jockey wheel axle from the lower cage's pivot point.
From what i can actually see, the pivot location of the lower cage is determined by the fixing point in the knuckle, to be specific, the mounting axle for the roller bearing which is part of the clutch mechanism. The rad cage, hence jockey wheel attaches to this same point as the shimano cage, it doesn't offset the pivot point or the top jockey form this pivot point in a different way to the standard shimano cage.
What does the RAD cage actually do?
It does offset the top jockey wheel.
It also improved the shifting on my setup by a large amount.
Before i fitted the cage it was very hit and miss. Now it's pretty much spot on.
Where are you buying these from?
It didn't improve my shifting at all tbh but it did mean I didn't need to spend hours setting the thing up- the standard mech was really very hard to get working right, I ended up setting it up on the turbo. The OneUp is just like setting up any other mech. Which is totally worth it! And also, should mean it's less demanding of perfect setup, more tolerant of knocks and dirty cables and that.
Could you just redrill & tap (thread) the std cage?
+1 for Rad love..
I've got the 42 oneup and the shifting on my medium xt is sweet and setup was easy......
I'd originally had a long xtr and it was very hit and miss 🙁
Sold - just bought one
Wavering on this. Getting mid cage xt with hope 40t. Should I just see how it runs first or would you users think it definitely improves the set up irrespective of what size range extended. And once more where from?
You can run it with the original cage and it will work OK. I ran my xt cassette with 40trex and SLC med cage like that for a couple of months. Using the red cage just make it work like a standard drive train, rather than like a very slightly sticky cable set up. Its worth 20 quid
"Wavering on this. Getting mid cage xt with hope 40t. Should I just see how it runs first or would you users think it definitely improves the set up irrespective of what size range extended. And once more where from?
POSTED 1 HOUR AGO # REPORT-POST"
It made quite a difference for me, shifts almost like a standard 11-36 set-up now.
I was using the oneup 16t cog but it didn't run smoothly and the 13-16 gap felt too large to me. Back on 15t now.
Improved my shifting 100%, now as slick as a standard XT setup.
.............can this be run on old 7090 di2 like the offset ki2 k-edge kit?
Substantial improvement to the shifting for me, it was always slow shifting one way or the other with the standard cage, but the RAD cage sorted it.
Interesting that the 10spd SRAM mechs are already like this with the jockey offset from the pivot and they shift just fine with the expander sprocket.
