Alternatives to Shi...
[Closed] Alternatives to Shimano brake hose. Deore M615 Brakes
9 Users
 benz
I need some longer hose for a pair of Shimano Deore M615 disc brakes.
Buying the Shimano kit(s) appears rather expensive, albeit with all the bits and pieces, so very handy.
I have the necessary fittings - barbs, banjo, etc.
What alternative hose can I buy by the metre to use?
Thanks all.
Posted : 13/05/2020 8:45 am
can't help with hose but while you are at it you can use car LHM fluid instead of the shimano unicorn tears as brake fluid. Its the same mineral oil.
I just got a litre for £5 from acecarparts on ebay https://www.ebay.co.uk/itm/191712702377
Posted : 13/05/2020 10:34 am
 pdw
Bear in mind that the barbs need to match the hose. Even Shimano do two different sizes that need different barbs.
Posted : 13/05/2020 10:47 am
 cp
re fluid, I've only ever had Shimano seal problems when using generic LHM. Using Shimano mineral oil I've had zero problems across 5 sets of brakes.
Posted : 13/05/2020 10:51 am
 FOG
When I got my first disc brake bike back in 2004 , the mechanic in Halfords of all places told me not to waste money on Shimano fluid and buy a bottle of ATF particularly the stuff made for Citroens. This has worked flawlessly over 8-9 bikes with Shimano brakes.
As for hose most bike shops have a drum of the stuff they will cut to length bearing in mind internal diameter. One of my bikes has Hope hose on Shimano with no problems.
Posted : 13/05/2020 4:41 pm
I use Uberbikes brake hose, available in colours, the internal ID is 2.1mm though.
Posted : 13/05/2020 7:57 pm
https://www.summittosea.co.uk/bikes-parts-accessories/brakes/shimano-sm-bh90-hydraulic-disc-brake-hose-price-per-half-metre__4239
Shimano hose is available to buy off the reel.
Didn't know you could just buy the hose, I thought the hose crimped on at the banjo end or is it push fit on to the banjo?
Posted : 13/05/2020 11:49 pm
Nope, it is a crimped on fitting, so if you have a banjo then you have to buy the correct kit (or bodge in something from a different manufacturer, maybe).
Posted : 14/05/2020 5:55 am
