Despite bodging, the cracked clamp on my Fox twin lockout remote is giving up the ghost.
I could order a replacement but it seems to be a fragile bit of kit - could I just use one of the Rockshox versions (I think cable pull is the same, even though Fox is push to unlock rather than push to lock)? Anything else worth considering?
The Orbea Squidlock works really well and is a sturdy piece of kit, it's standard issue on their bikes with Fox f+r. There's two versions, one for forks/shock and one for forks/shock/dropper.
Current one is two position rather than three - I'm guessing it won't magically transform my FIT4 fork/shock into a 3-pos version?
Hmm, not sure but I doubt it!
Cheers!
Anyone know if the Rockshox remotes - twinloc/twistloc are likely to work, and are they any good?
