Alternative to Fox ...
[Closed] Alternative to Fox Fluid/oil
5 Users
Hi,
does anyone know of a cheaper just as good alternative the the fox branded fluids/oils?
cheers
Jon
Posted : 27/01/2013 4:32 pm
The red is silkolene RSF 10wt.
Green is Torco which is about the same price and the float fluid is Torco assembly paste if memory serves.
There's a chap called Peter VanDeran or something like that who published a lovely table that compares all the centi-stroke values for most fork oils. This is the true measure rather than the nominal wt.
Posted : 27/01/2013 4:43 pm
peter verdone
http://www.peterverdone.com/archive/bikesuspension.htm
i like putoline fork oil, works for me, the float stuff is not so expensive 1 bottle will last ages, but i have used a bit of gear oil in the air chamber before, worked OK.
http://www.putoline.com/en/
http://www.putoline.com/en/products/catalogue/segp_offroad/psusp/464/off-road/suspension-oils/hpx-10/
Posted : 27/01/2013 4:48 pm
Great thanks thats helpful!
Posted : 27/01/2013 4:57 pm
Motul you'll get it from any good motorbike shop !,all there oil is the db's !..just check the weight of fork oil
You require ..
Posted : 27/01/2013 5:16 pm
even Fox have apparently stopped using the Float fluid(repackaged 90wt gear oil) in the lowers as they've finally realised that as soon as the fork goes through a few cycles the lower weight oil in the bath will jusy flush the Float out of the foam rings...
I use Silkolene in all my forks (fox Float RL, RS Reba, RS Rev, RS Lyrik). I dont think for one second Fox, RS etc have refineries that produce their own oils, and if Silkolene is good enough for race-quality motorcycle forks its good enough for MTB.
Posted : 27/01/2013 5:44 pm
