Alpkit Koala on a r...
[Closed] Alpkit Koala on a roadbike?
15 Users
Has anyone used a Alpkit Koala saddle bag on a road bike? I want to do some rides in the dales in the winter, and want something to carry an extra layer or two, just in case! My main concern is, is it too big? and will I have the clearance from my back tyre. All the pictures I've found ,show them attached to MTB's so someone who's used one with a road bike would be nice.
Posted : 08/11/2016 5:46 pm
Depends on how much clearance you have between saddle and tyre? Plus you'll need at least a couple of cm clearance IME as the bag will slip down the seatpost a bit. Orlieb large seatpack is another option - doesn't slip down either.
Posted : 08/11/2016 5:57 pm
Hi. Yes it works great, as long as you have enough seat post probably 15cm minimum. Have a look at the wildcat tiger with a alpkit tapered bag. I think wildcat also now do tapered bags but not tried them. I prefer this solution to the koala. [url= https://goo.gl/photos/K7SnCZZEtXLLwEZs8 ]picture of my bike in full setup[/url]
Posted : 08/11/2016 6:06 pm
Similar but different...
I've used a Revelate Viscacha on a roadbike.
[url= https://c4.staticflickr.com/4/3842/14870426299_4bec76b2e2_b.jp g" target="_blank">https://c4.staticflickr.com/4/3842/14870426299_4bec76b2e2_b.jp g"/> [/img][/url][url= https://flic.kr/p/oE3PEk ]P1010510[/url] by [url= https://www.flickr.com/photos/druidh2000/ ]Colin Cadden[/url], on Flickr
I've also seen various (Revelate, Wildcat, Alpkit) seatpacks on a number of roadbikes - mostly those doing LEJOG or JOGLE - so it can definitely be done depending upon your saddle/tyre clearance.
The largest of the Ortlieb saddle bags is a good call. I use one of them to carry an insulated jacket, spare pair of gloves and a couple of other bits on my roadbike when conditions dictate.
[url= https://c1.staticflickr.com/8/7356/16287570160_be4a74bce5_b.jp g" target="_blank">https://c1.staticflickr.com/8/7356/16287570160_be4a74bce5_b.jp g"/> [/img][/url][url= https://flic.kr/p/qPh4ab ]DSC_0048[/url] by [url= https://www.flickr.com/photos/druidh2000/ ]Colin Cadden[/url], on Flickr
Posted : 08/11/2016 6:12 pm
It works ok with my Boardman. Alpkit have a good returns policy so give it a try.
Posted : 08/11/2016 6:17 pm
Just Google images for transcontinental race bikes, you'll see loads of examples of people using saddlepacks without any trouble. Be aware that most designs work best if they're full up - half empty ones tend to swing/flap around.
Posted : 08/11/2016 6:58 pm
 JoB
are you sure you need a Koala for just a couple of extra layers?
a Kowari should do fine if you're stuck on getting an Alpkit bag
Posted : 08/11/2016 7:06 pm
I really like my koala. Have used it for overnighter in Peak this year, also use it for occasional commuting on Day One. I think it would be to big just for extra layer or two.
[URL= http://i1362.photobucket.com/albums/r699/mf_kuman/image_zpsua7b81cn.jpe g" target="_blank">http://i1362.photobucket.com/albums/r699/mf_kuman/image_zpsua7b81cn.jpe g"/> [/IMG][/URL]
Posted : 08/11/2016 7:21 pm
Like this?
Posted : 08/11/2016 7:22 pm
 OCB
The amount of space will be the issue I guess ...
I normally (*1) use a Wildcat Tiger with an Alpkit drybag shoved in it.
I do tend to use a long pedal strap to just tighten everything up a bit and limit the wag when the bag is only partially full (when I can't decide what to wear) - plus it's an extra luggage point / strap if I need it (or if something breaks).
(*1) I sometimes use a Bikepack.eu bag.
Posted : 08/11/2016 7:44 pm
Thanks all for the pics. I'd never have a problem filling it. Packing light is not in my nature.
Posted : 08/11/2016 8:04 pm
Revelate Pika is designed specifically for this purpose.
Posted : 08/11/2016 8:21 pm
Alpkit Koala on my friends Tricross
And kind of in shot on my XLS on same trip
Filled with a sleeping bag, bivi bag and gas canister.
Posted : 08/11/2016 9:22 pm
here's mine
[url= https://goo.gl/photos/mLyfqB2iwBZJFULE9 ]linky[/url]
Posted : 09/11/2016 1:56 am
have a check of seatpost height and overall saddle rail to tyre clearance. This is my Revelate Pika on my previous CDF. I couldn't get the bigger one, like scotroutes', in due clearance.
[img][url= https://c5.staticflickr.com/6/5512/11514982004_a0649d60e0_z.jp g" target="_blank">https://c5.staticflickr.com/6/5512/11514982004_a0649d60e0_z.jp g"/> [/img][/url][url= https://flic.kr/p/ixxhYu ]P1010123[/url] by [url= https://www.flickr.com/photos/31347922@N03/ ]iain.clow[/url], on Flickr[/img]
Posted : 09/11/2016 8:42 am
Fits fine on my Tripster, and my seat is fairly low. Its stuffed with a change of clothes for 2 in the photo below
[img] https://goo.gl/we7ZAi [/img]
Posted : 09/11/2016 9:21 am
Here's a couple more where it's been fine too. No clearance issues at all, although saddles quite high I suppose.
Posted : 09/11/2016 9:33 am
