Allen bolt size for...
[Closed] Allen bolt size for Shimano rear mech clutch cover
5 Users
Any one know what size (thread and length) the 3 allen key bolts/capheads are that are used to fit the clutch cover on a Shimano shadow plus rear mech?
Mine are seized in and I need to drill them out.
cheers
Posted : 02/03/2015 12:43 pm
think they tell you in here
Posted : 02/03/2015 12:46 pm
thanks for the reply but unfortunately they don't.It does say I need a 2mm allen key though
Posted : 02/03/2015 4:53 pm
I can't find the size listed anywhere but there's a p-cover bolt set available from Madison...
http://www.madison.co.uk/products/cycling/transmission-braking-components/rear-derailleurs/rd-m786-p-cover-bolt-set-3-piece/
Posted : 02/03/2015 6:00 pm
My apologies, I now get why you want the size and length (I know, dim shit). I'll whip one out tomorrow morning, take the measurements and let you know.
Edit : From memory they're about 12mm x 3mm but better to be safe n all that...
Posted : 03/03/2015 12:23 am
Rather than drill them out (which will fail) try and tap a small torx or spline bit into the hex head and use that to remove them.
Posted : 03/03/2015 12:55 am
2mm hex key would normally suggest an M2.5 cap head screw. M3 is normally 2.5mm allen key. But then shimano do have a habit of getting unusual bolts produced like the small head ones used on HTII crank arms.
Posted : 03/03/2015 1:16 am
Okay, just had the verniers on one I just removed - 2.88mm x 10.34mm
A weird shaped thing, though, not just a standard bolt.
Posted : 03/03/2015 11:10 am
