Alfine chainring .....
[Closed] Alfine chainring ... eek! HOW MUCH?
8 Users
Following on from my post about which chain to use (thanks for your replies) I am now sourcing the chainring. The few retailers who have them in stock are asking £59.99. For a chain ring. I wouldn't mind if it was a Campag one or Dura Ace, but it isn't.
Why is it so expensive? Is it stainless steel maybe? Gold-plated? Ti?
Posted : 31/03/2012 12:42 pm
 nuke
Why do you need an Alfine chainring? I use a standard 9-speed Deore steel chainring with my Alfine 8...think it was about £12.
Got one of these as well which I'll probably fit when the deore ring wears out...
http://www.ukbikestore.co.uk/product/54/dh3/fsa-dh-mtb-chain-ring-3mm.html
Posted : 31/03/2012 12:54 pm
As above, use any normal chainring, as long as it isn't a singlespeed 1/8th width.
I just removed the inner and outer rings, and kept the middle ring.
Posted : 31/03/2012 1:16 pm
Because I couldn't find any rings which were 45 T - I'll have another look online
Posted : 31/03/2012 3:32 pm
You can buy the whole alfine chain set including bottom bracket from Rose for £45.
Posted : 31/03/2012 4:53 pm
 mboy
On One are selling the Alfine cranks with chainring for £59... A whole lot better value than the chainring on its own!
Presumably this is for a road/commuter bike if you need a 45T for it?
Posted : 31/03/2012 4:55 pm
Rose bikes have crankset c/w 45t for £45 BUT not compatible with MTB frame , what frame you got Karin ?
Posted : 31/03/2012 5:04 pm
Yes, my Scott Sub 10, it's a commuter bike. It would go against everything I believe in to buy a whole chainset when I only need the ring.
Posted : 31/03/2012 5:08 pm
OK check your BCD and get on to Spa Cycles, Harrogate they do plenty of 45T chain rings and they are very helpful to boot.
Posted : 31/03/2012 6:04 pm
Thanks jamesco, will do, the bcd is 130mm btw
Posted : 31/03/2012 8:27 pm
 mboy
Buy whatever's cheapest, then sell whatever you've got left on the classifieds or on eBay surely? I believe in common sense and saving money myself, seems to have worked out so far!
Posted : 01/04/2012 12:11 am
Or get a Goldtec chainring for £35: http://www.mountainbikecomponents.co.uk/items.asp?CategoryID=32&Name=Goldtec+1%2F8th+Track+and+Single+Speed+Chainrings
Or a Surly chainring (44T) for £40 - it is steel so should last ages.: http://www.wiggle.co.uk/surly-stainless-steel-38t-to-44t-chainring/
Posted : 01/04/2012 12:29 am
130 is std road size, you should find something close, would a 42T not do?
Posted : 01/04/2012 6:16 am
You may be able to fit an outer 44 or 46t ring to the middle ring position on a triple crankset. (not that it looks very pretty)
Posted : 01/04/2012 6:55 am
