Air leaking on Tube...
[Closed] Air leaking on Tubeless via the stem hole - help please!
4 Users
OK set of wheels and values i've been using for the last 2 years with no problems (Stans values and Spank Ozzy 295s)
Replaced a tyre and air was escaping from the valve hole. Tried to tighten the value up but it was getting a bit daft as there is no way I'd get it undone on the trail if I needed to stick a tube in! It was still mildly leaking.
So replaced the tape (gorilla tape as I've always used) still was leaking, kept fiddling with the value and all of a sudden the air loss stopped, so about a week then all of a sudden one morning flat again.
So tried replacing all the tape again and a piece of old innertube as a washer between the value and rim.
STILL LEAKING!
I must be doing something wrong any ideas?
Posted : 22/05/2018 5:02 pm
It's quite possibly NOT the valve hole - that's just the easiest place for air to escape. Check your tape overlap. If that's not stuck down well then air can get under that, into a spoke hole and out at the valve hole.  That can exhibit occasional success/failure depending on how your sealant tries to fill the hole.
Also - is your tubeless tape as wide/wider than the rim bed? If not then air could be getting under the tape at any point.
Posted : 22/05/2018 5:05 pm
There is a big overlap, maybe I need to do 2 loops of the tape although might make getting the tyre on a bit trickier.
Yes appreciate the air might be exactly from the value, I suppose I could try another value too just in case the rubber bung (hope that makes sense) isn't seating properly.
Posted : 22/05/2018 5:11 pm
Leaks at the valve were known issue when the original 28H Oozy 295s rims first came out - see MTBR forums I think.  Reported fixes were to put a rubber o-ring between the rim and the valve lock ring and/or urethane glue around the inside of the valve before tightening it completely (Shoe Goo, Evostik Serious Glue, Seam Grip, etc).  I did both when I first set them up and never had leakage issues in 3 years.
Posted : 22/05/2018 5:15 pm
Interesting Iornholio I can try that. Its weird as I have two sets of wheels on the same rims and it's only just started.
Posted : 22/05/2018 5:19 pm
Is the tape wall-wall or just a strip?
Posted : 22/05/2018 5:29 pm
Just slightly over the strip, a few mm either side before the wall.
Posted : 22/05/2018 5:49 pm
