Does anyone know of a dropper post lever for cable operated droppers which has a return spring? as in its spring loaded.
The reason being, I have a CB Highline on my Evil Calling which has been pretty much trouble free but has a little bit of slack in the lever which I can't seem to dial out. new inner and outer doesn't help either. I've seen all the vids about troubleshooting and all that.
Ive read somewhere that the spring in the highline is a bit weak and the cable has to be super smooth and pristine which mine is, so all that I can presume is that the internal routing maybe has too tight a bend in it. Im wondering if a sprung return lever might help.
Any info gratefully received
Watching with interest
I too have noticed what the OP is on about, but I dont think there will be as the highline has the cable mounted the other way around compared to most other posts.
I just replaced my spesh command post with SRL lever and the SRL lever was nicer. I do wonder if I could chuck the SRL back on and use some kind of cable grommet in the lever, but with how much of a faff I found fitting it I dont want to touch it now its fitted and working fine!
