After a 29er 120mm ...
[Closed] After a 29er 120mm fork.. any recommendations?
12 Users
Contenders so far are as follows (all non boost)
Rock shox Rebas RLT
Rock shox Sid RL
Magura TS6 (don't know much about these)
Fox 32 Talas FIT CTD
Marzocchi LR320
I am mainly doing XC but do like the odd drop off and jump 🙂
Posted : 12/09/2018 5:11 pm
X-Fusion Slide is 120mm 29".
Can't remember what model it is but a mate has a travel adjust X-Fusion (think it's 110-130mm) on his Pivot 429c and it's superb. Can't see why the Slide would be any different.
Posted : 12/09/2018 5:16 pm
IL take a look, IV been advised the maguras are not the best - however I can get them pretty cheap
Posted : 12/09/2018 6:47 pm
I just bought a Fox 34 performance elite for £350.
It's a 44mm offset but I'm thinking I'll not actually notice.
Posted : 12/09/2018 8:05 pm
I managed to nab a 2018 120mm pike for £485 from chain reaction!!!!!!! That includes my 10% British cycling discount .
Posted : 13/09/2018 10:15 am
Boost debonair
Non boost solo air
Posted : 13/09/2018 10:43 am
Can I ask where? I currently have Float 32s but have fancied 34s for a while...
Posted : 13/09/2018 10:46 am
It was boost, but the 34 was/is available at CRC/Wiggle
Posted : 13/09/2018 10:54 am
I recently got a set of Ohlins RXF34s. I like. A lot. Very coil-esque in feeling, track the ground very nicely, and very supple. Night and day when compared to my old Rockshox Revs.
I didn't get them new however, they are a touch spendy.
Posted : 13/09/2018 10:58 am
I might be selling these - brand new but they don't match my new frame
Posted : 13/09/2018 11:46 am
It’s a 44mm offset but I’m thinking I’ll not actually notice.
Hi Onzadog,
I don't suppose you could let me know the 4 digit code found on the rear of the lower legs? I'm looking to see if these can be extended to 140mm with just an air shaft swap.
Thanks, Tom
Posted : 13/09/2018 4:29 pm
My 120mm 29er is rocking a Yari which was a huge improvement over the previous Reba...
Posted : 13/09/2018 4:39 pm
Pike with 120 airshaft.  I could maybe sell you a pair if you are interested?  They are 2014, 140mm bought from and serviced by local bike shop (serviced recently in the summer).  Done about 800miles on them.  I also have the aforementioned 120mm airshaft.  Let me know if you are interested.  They are not boost.
Posted : 13/09/2018 4:53 pm
@tomtomr.
C7XC. Let me know what you discover. I might like to extend mine one day.
Posted : 13/09/2018 5:21 pm
I had X-Fusion slides but changed them for X-Fusion Trace's set at 120mm. They're much better - track much better with the bigger stanchions, unsurprisingly. Whatever you go for I'd recommend 34mm stanchions as a minimum requirement.
Posted : 13/09/2018 10:14 pm
Thanks Onzadog
James from J-Tech has confirmed that the damper in these is limited to 120mm. To extend the travel you'd need a new damper (£250) as well as the air shaft.
Tom
Posted : 14/09/2018 8:54 am
@tomtomr, cheers. J-tech is where I went for the evol air spring upgrade for these.
I did look at the spec from the code. It said 120 but it wasn't clear to me if that was meant as the maximum travel or the current travel.
Posted : 15/09/2018 7:33 am
 tdog
@snaps, just outta interest seeing as they are gorgeous and all that jazz- how much?
Posted : 15/09/2018 3:49 pm
https://www.pinkbike.com/buysell/2442065/
Posted : 15/09/2018 5:51 pm
