Where exactly do you pick up the new bit on Y Wal and where does it end ?, rode the trail a few weeks back but must have missed it !
Two new bits, one on 373(I think), which is a hairpin right to add a small loop, the other comes after the Graveyard, don't take the final descent (zig-zags), follow the fire road on to it's end, turn right, and then take the turning right into the woods and follow the singletrack all the way back to the end of the Graveyard. Nice fast flowing singletrack all the way, prob won't be long before unecessary braking chews it all to hell 🙁
Ditto. Not sure how it is way marked.
Oh, and a new link from 373 to Graveyard too, pretty obvious, turn right instead of left as you leave 373 by the picnic tables, turn left at the end and go up the fire road to the start of Graveyard.Unless somebody has removed the signs, all bar the extra loop on 373 were well marked a couple of weeks back.
Y Wal?
Is that taffy for The Wall or are there some new trails up there to have a gender at?
Y Wal is daispeak for The Wall. Although there are some new bits. Looking forward to the reopening of Penhydd in the summer!
As you approach zig-zag stay on the fire road (signposted as Y Wal out) this will take you up hill before dropping you into the new single track section. This will pop you out on the fire road you have just biked along before zig zag. This time around follow Y Wal (in) sign which will take you onto zigzag. Hope this helps.
Cheers for the replys will be back down to Wales asap to try out those bits , on a seperate note whats the state of play on the whites level climb is it still open ?
White's is fully open, up and down.
Oh good ,think ill try whites on friday then
