Advice with Fox har...
[Closed] Advice with Fox hardware
4 Users
Hi. I have a Hightower LT which has the Fox DPX2 shock on the back but I have just purchased an X2 to replace it.
Will I need new hardware to fit the shock or will the kit which is on the DPX2 be OK?
If I do need new hardware does anyone know the sizes or how to check?
Posted : 13/05/2018 12:13 pm
The old kit should fit, but you may damage the plastic bushes when removing them (i've round prying them a little at a time with a Stanley knife blade quite effective). If you need to order new parts, you'll need to specify overall width of the centre sleeve (measured to within 0.2mm with a vernier caliper, and possibly different at each end of the shock), and the diameter of it's bore, usually 6 or 8mm.
Posted : 13/05/2018 1:22 pm
If it helps, I have a hightower LT and replaced the shock (although it was with a DVO Jade), the bushings I bought were 22x8 front and rear, can't remember 100% but I'm about 90% sure its tjat. Bought some in that size for my nomad when I had that (was a 15 model).
Posted : 13/05/2018 11:47 pm
Thanks, the shock should be here soon so fingers crossed they will fit.
where did you get the bushings from?
Posted : 14/05/2018 10:36 pm
New X2s would normally come with bushes fitted, so you should be fine.
Posted : 15/05/2018 8:59 am
I got some offset bushings from offset bushings .com. You can get standard bushings from them as well as from tf tuned etc.
Benpinnick - New shocks don't tend to, if you go on TF tuned and look at shocks it normally states they sell springs and mounting hardware separate.
Posted : 15/05/2018 1:42 pm
