Advice - Respraying...
[Closed] Advice - Respraying/Powder coating a frame
8 Users
Thought I'd ask on here, gone through some old threads.
Instead of my initial thoughts of buying a Privateer 141 saw a Sentinel for sale but will need a respray/repaint.
Intention will be to send it off to a professional set up
Any pitfalls or things I need to consider?
Ta
Posted : 12/03/2021 4:41 pm
For powdercoating, just make sure they have a reputation for bikes and will properly mask threads etc.
You should totally ask Bignose customs though aka @bigyim on here. He does amazing paint jobs 👌
Bignose customs on Insta
Posted : 12/03/2021 5:01 pm
Thanks @kayak23 will pm @bigyim
Posted : 12/03/2021 5:07 pm
He's got my fork lowers at the moment... can't wait to see them finished 🙂
Posted : 12/03/2021 5:11 pm
If the frame is alloy make sure it’s not being sandblasted to remove the old paint. It’s better to be chemical dipped - and the powdercoater also should run the oven thing at a temperature lower than that of the alloy heat treatment after the frame welding or it could weaken it.
Posted : 12/03/2021 5:27 pm
What's the current rust prevention?
I've waxoyl in mine and it's supposed to be a bugger to remove prior to a respray.
And if it's not removed it'll bugger up the new coat.
Posted : 12/03/2021 5:28 pm
@bigyim did my 7 year old carbon road bike recently and it looks ace. He's also going to be getting my new steel FS front end when it arrives.
Posted : 12/03/2021 5:46 pm
Your best bet is to try and find someone with a reputation for powder coating bikes locally. They'll then know what they are doing.
In Newcastle I use Bettablast and they are superb. Understand the stripping and surface prep that's best, do a really good job of masking and get a good finish.
For paint it's more of a skill, just because you have the kit doesn't mean you get the results. There are people/companies that will do it but they are often pricey compared to basic powdercoats. Bigyims on here look good, I hear good things about Argos. I'm sure their others.
Personally I'd not bother with rust prevention on the interior. Its a relatively low corrosivity environment. Again talk to your painter. Removing greases and waxes should be something they are capable of doing. It's standard paint practice (ISO12944-4:2017)
Posted : 12/03/2021 6:27 pm
thanks @jonba and @joebristol
Posted : 12/03/2021 7:25 pm
Thanks everyone for their kind words about me. Makes me blush.
I tend to go chemical dip over sandblasting as it removes any corrosion and seems More gentle on the threads.
Then I tend to lightly cavity wax the interior of the tubes with a long pokey probe just for my own piece of mind that I’ve done all I can to make the job last
Posted : 12/03/2021 7:35 pm
@bigyim just dropped you a pm
Posted : 12/03/2021 7:41 pm
