Advice re neck / he...
[Closed] Advice re neck / head ache from position please
5 Users
Hi all,
Having an issue on one particular bike I ride - steel hardtail / wide flat bars / bar ends / 90mm 10 deg stem - 100mm fork - any ride over 3 or 4 hrs and I get crippling neck ache which ends up in a headache - its a pain right in the middle of shoulders and it radiates up...
I know its this bike and not dehydration etc as other hardtail / full sus = no problem plus i drink a fair bit. Wondering if I need a higher set of bars or a diff stem...
any thoughts
cheers
paul
Posted : 09/06/2012 9:21 am
 DT78
If you have other bikes that you are happy with, measure the setup and see how it differs.
Posted : 09/06/2012 9:27 am
How wide are your bars?
Posted : 09/06/2012 9:30 am
 DT78
Other more effort option is setup a camcorder, put a bike you are happy with the setup on a turbo trainer, record yourself pedalling, then swap to uncomfortable bike. Watch vid and see if you can see difference in position. Could be anything.
Posted : 09/06/2012 9:34 am
thanks so far,
the bars are 680 ish -position is about 30mm lower at the front vs other bikes and about 25mm shorter... other bikes have riser bars....
hmmm
paul
Posted : 09/06/2012 9:40 am
for me and gf reducing bar 'reach' worked (raising bar height/ shortening stem/seat forward etc) I'd also make sure controls are lined up etc
Posted : 09/06/2012 9:51 am
Shorten the stem
Posted : 09/06/2012 9:57 am
