Hi,
Anyone can offer any advice it would be much appreciated, When I was doing my monthly fork check yesterday, I found I have the followng problem.
When using my shock pump (with adapter) to pump air in to the ETA Air Chamber on my forks (only upto 30psi), the air goes into the chamber, but after 3 seconds or when I unscrew the pump - it's back to 0 psi.
Is it my pump, is the chamber faulty or something else...
thanks
Try tightening the valve core, could be loose.
Or for what they cost put a new one in.
Thanks - will investigate
Perhaps an air seal has gone, worth dropping Windwave an email on that one I thinks
