Looking to get a steel frame powder coated
Is it just a case of picking the colour and telling the to do it?
Or do I need to seal the threads up for the bb and where the headset inserts?
Any advice much appreciated
I got a mid 90's Kona powder coated by these guys [url= http://www.realitymotorworks.com/index.html ]Link.[/url]
I just took them the stripped down frame, chose the colour and they sealed all the threads for me. Top job in about a week and cost about £50 I seem to recall.
Main hint i have is to ask around, not all powdercoaters are the same. A good coater will have the knowledge and skill to mask/seal it up properly for you, that's a useful indicator when you're dealing with them, if they don't know, and don't demonstrate that they know how important it is with bikes, then walk away.
Motorbike crossover is good- you know Triple S and ESP do good work because if they didn't, some large bearded man would have murdered them by now.
If it's steel you could get it stove enamelled - even nicer.
A set of old bb cups loosely threaded in will protect the bb threads, and possibly some old headset cups half pressed into the frame.
Nothing you'll want to re-use though obviously, as these are just a good (sacrificial) way of keeping the bores/threads clean
With a good coater the answer would be yes. I'd still go through my concerns with them as a conversation is easy than fixing the problem.
Definitely best to use someone who regularly does bike/motorbike stuff, http://fastlinecoatings.co.uk/ in Preston are meant to be very good
I had a frame coated by someone who did not specialise in bikes. I simply explained what needed be masked before hand. Frame came back with no issues and a really good finish. I think as long as you explain it you should be fine.
