Is this possible? I see that you could get shims for the older models but apparently they don't fit more recent versions. I don't think there's any built in adjustment like 105 and upwards? Thanks.
Have you taken a look on shimanos website, exploded views and tech docs are usually pretty good
Shimano tech docs indicate a 2mm allen key under the top of the hoods for lever stroke adjustment
Thanks. Can't believe I missed that. I hadn't pulled the hood back far enough to see the second hole where the allen key adjustment is. I'd just assumed that they didn't have the same adjustments as 105.
What an excellent value groupset. Every time I buy a shimano groupset a level below the last that I had it makes me wonder why I ever bothered spending the extra money.
