Adding cables guide...
[Closed] Adding cables guides to a frame
4 Users
Just putting disc brakes onto a frame with no guides. I can use a couple of the old wire brake guides but towards the back of the frame there's nothing. I've seen a few expensive zip tie on guides but there must be something better or cheaper (rather than just a zip tie around the frame)? Any ideas?
Posted : 23/05/2017 12:31 pm
[url= https://www.bike-discount.de/en/buy/jagwire-brake-cable-conduction-mounting-aluminum-532589/wg_id-475 ]Something like these? [/url]
I recently got hold of an old Jack Flash for messing about on and thought about these when installing some disks, I then thought, nah. I stuck with cable ties for rustic authenticity (and the fact that I always have a bag of them knocking around the garage)
Posted : 23/05/2017 1:07 pm
Can you drill out the existing guides to fit a hose through?
Posted : 23/05/2017 1:09 pm
There's a voodoo way of loop-de-looping a zip tie so that it holds a cable nicely rather than just wrapping it against the frame. You use a washer or similar, pass the zip tie through it, around the cable then back through the washer and around the frame.
Posted : 23/05/2017 1:13 pm
