Basically just want to check the pressure and maybe add some air to my forks, am I right in thinking this is possible with the aforementioned forks and if so how??
Ta,
Phil
unscrew cap on top of fork leg. screw on shock pump and check. bobs your uncle and fanny's your aunt !!!
unless you have the coil version
Well it's got lock out on right leg and preload on left??
How would I know if its a coil?
If its got a preload knob then its a coil spring fork not air.
Turning the preload knob towards + will make them a bit stiffer initially.
And the award for biggest div on Stw goes too...........Me 🙄
