Add more travel to ...
[Closed] Add more travel to 2016 Lyrik Air? Anyone done it?
4 Users
Just as the intro says, looking to make my 150 Lyrik Air RC from 150 to 160mm of travel. Any ideas?
Thanks
Posted : 24/09/2016 2:31 pm
Provided the fork's capable of it, it should just be a case of replacing the air shaft. What I don't know though is whether all Lyriks are capable of all lengths, rockshox historically have enjoyed dicking about with this especially for OEMs.
Posted : 24/09/2016 3:07 pm
[url= https://sram-cdn-pull-zone-gsdesign.netdna-ssl.com/cdn/farfuture/owLRs0rHuRiZOCl6jbgCc0NkH-Xqkrf2WWqYIMaagn8/mtime:1469823241/sites/default/files/techdocs/2017_rockshox_spc_rev_a_0.pdf ]SRAM parts[/url]
Check pages 85 & 86. I think you just need a new spring shaft assembly. For my coil Lyrik I needed a new spring and a shaft. Bought them from bike24.de
Posted : 24/09/2016 3:22 pm
Parts 26 & 27? Just to clarify - I haven't done it! Can anyone confirm?
Posted : 24/09/2016 3:27 pm
If were talking current gen lyrik (as in 2015+) then yes no worries. get the right 150mm Lyrik/Yari airshaft and swap it out. They will go from 120 all the way to 180mm (Wheelsize dependent - but 150 is common on all variants).
Posted : 24/09/2016 5:40 pm
I had a look on bike24.de and they of course have all the air cartridges but for the 2016 model - 07-15:d
I just got a 650+ variant and want to slacken the head angle by propping it up 10mm.
Posted : 24/09/2016 6:14 pm
You need this part: 11.4018.026.004
It may be listed as a 150 Pike 29 air shaft, which it also is, so don't worry about that if it doesnt list the 160 Lyrik bit. Its still the right part.
FYI I see that 160 is as long as you can go on a 29er/650b+ Lyrik.
Posted : 24/09/2016 6:29 pm
Thanks Ben much appreciated.
Posted : 24/09/2016 6:41 pm
