Absolute Black oval...
[Closed] Absolute Black oval ring won’t fit?
8 Users
Not sure if I’m being stupid, pretty sure I’ve ordered the right thing. I’m converting a friends Boardman Team FS from 2x10 to 1x10, it has FSA cranks. I’ve ordered a 94BCD oval ring, the holes line up but it won’t fit, it fouls on the arms -
1
2
Posted : 02/03/2019 4:28 pm
you need 96bcd.
Posted : 02/03/2019 4:40 pm
Bugger! Thanks
Posted : 02/03/2019 5:08 pm
I had this. If the holes line up, then just file a little off the ring next to each hole. This will allow it to sit into the spider.
Not sure why they leave a bit too much meat on there. All the other AB stuff I've had has been faultless.
Some manufacturers do a 94/96 ring which will fit both. The holes are just slightly ovalised as they are so close in size.
Manufacturers are right ****ers sometimes..
Posted : 02/03/2019 5:22 pm
They look like they would line up, tempted to get the file out but if it doesn’t fit right I’ll be wishing I’d just ordered a 96 and sold this one.
Posted : 02/03/2019 5:29 pm
I guarantee as it's a mates bike that if you bodge it then in the future a totally unrelated issue will happen with the chain ring.... then it's automatically "your fault".Lol
Posted : 02/03/2019 6:38 pm
That’s what’s in the back of my mind! I’ve listed it in the classifieds and will order another up.
Posted : 02/03/2019 7:08 pm
I think I need more help. Are all 96BCD the same? Will this fit an FSA crankset for example?
https://www.ebay.co.uk/itm/Works-Components-96BCD-Oval-Narrow-Wide-Chainring-M8000-SLX-Fitment/312421415762?_mwBanner=1&ul_ref=https%3A%2F%2Frover.ebay.com%2Frover%2F0%2F0%2F0%3Fmpre%3Dhttps%253A%252F%252Fwww.ebay.co.uk%252Fulk%252Fitm%252F312421415762%26rvr_id%3D0%26rvr_ts%3D43d727821690ac3c42f6a776fff5ccf2&ul_noapp=true&pageci=0d824426-ec76-4364-96b6-8ba36f9f17e2
Also as this bolts into the spider arm and not through it (opposite direction). I’ll need longer bolts I think, any idea on length? This is a lot more complicated than my Shimano cranks!
Posted : 03/03/2019 1:57 pm
No that Shimano ring will NOT work. It's asymmetrical so the bolts are not at 90deg spacing.
Posted : 03/03/2019 3:35 pm
A 94/96 will work as the boot spacing is correct
A 94/96 won't let you do 30t though as 30t likely has the thread in the chainring so fixed position is critical.
Here is a ring that will work in 32 or 34t
One up
Posted : 03/03/2019 3:43 pm
Ok, so I now have a 96BCD Snaggletooth ring and the tabs appear to large on this also? The holes do line up though.
Snaggle
Posted : 07/03/2019 7:01 pm
that snaggletooth 'looks' like it has recesses in the ring to fit the 'backs'/nuts of a chainring bolt, whereas your crank 'looks' like it has threaded holes on the spider - can't quite tell from the pic.
Posted : 08/03/2019 9:23 am
Yes the spider has threaded holes. Have I got the wrong chainring again? This is a minefield, only ever had Shimano cranks on my own bikes so things have always been straight forward.
Posted : 08/03/2019 10:32 am
(Doesn't help but) whenever I've had to replace parts on an FSA chainset, I've always just bought a Shimano chainset and gone from there 😀
Posted : 08/03/2019 10:47 am
The Blackspire website makes quite a point about that chainring being compatible with all SHIMANO 96 bcd cranksets. It doesn’t say so — but therefore it’s probably not FSA compatible, (sorry)!
Posted : 08/03/2019 11:01 am
on the plus side.. if you fettle those tabs then the shoulder in the bolt drilling will help center the ring.
Posted : 08/03/2019 4:04 pm
Update, filed a few mm off each tab and it fits a treat now.
Posted : 12/03/2019 3:43 pm
Nice one op.
What a saga though to do an "easy" job. Hope you're mate buys you a few beers! Lol
Posted : 12/03/2019 4:55 pm
It’s always the 5 minute jobs isn’t it!
Posted : 12/03/2019 7:30 pm
No such thing as a 5 minus job. When I attempt them anyway! Lol
Posted : 13/03/2019 11:38 pm
Remember when crank BCDs were sane?
Posted : 13/03/2019 11:57 pm
