A2Z caliper mount?
[Closed] A2Z caliper mount?
10 Users
 benz
Xs Ti frame bought off here to build up into first 26" wheel mtb for my soon to be 10 Daughter.
I have all the necessary bling bits and pieces in the spares shed to make it nice.
However, it foes not have rear caliper mount. I could get Enigma or similar to weld one on but has anyone used an A2Z mount? How did it work?
Thanks.
Ps - If anyone has one in a spares box I'd be happy to buy it...
Posted : 02/04/2016 9:20 am
I've used the A2Z one, works fine.
I'll look in the garage later and see if I can find it
Posted : 02/04/2016 1:32 pm
A2Z works if the dropout is flat. Still around on eBay for $30 or so.
Had one on an old GT frame. Solid, no issues.
Posted : 02/04/2016 3:53 pm
I've found it, or at least I can see it on a frame at the back of the loft. If you want it send me your address and I'll go up and fight the spiders for it tomorrow!
Posted : 02/04/2016 8:12 pm
Ah, sent one to the bike recycling container at the tip last year, attached to an old Kona frame. Did the job - aligned fine. Fugly and heavy though.
Thought about disc front and really nice v-brake or magura rim brake on the rear? Especially for a light rider...
Edit: just looked on eBay....there's some lovely xtr v's and late-model hs33s - I'd do that rather than bolt on disc mount.
Posted : 02/04/2016 8:54 pm
 kcal
I have disc front and XT V on rear on my M2 - works perfectly well, don't really notice different levers and feedback, although through mud I really wish I had a disc on the rear too!
Posted : 02/04/2016 9:09 pm
Obvs you'll need a brake surface on rear rim.......
Posted : 02/04/2016 9:12 pm
 benz
Phil56,
Thanks, email on its way to you.
Others, yes, could stick a nice v or Magura on tha back, but my OCD would not deal with lever differences...even on my daughter's bike. But a pair of SLX brakes and decent disc wheels were also in the garage stock...
Result!
Posted : 02/04/2016 9:26 pm
Just used one on an old GT updated for canal commute duties.
It wouldn't fit properly so I dremelled the chuff out of it. Works well.
Posted : 02/04/2016 9:45 pm
As noted works well assuming your dropout is flat
Dead easy to fit - if it fits 😉
Posted : 03/04/2016 12:23 am
 benz
Thanks all.
Drop out is typical brutalist industrial function over form - flat and square. Fingers crossed.
Phil56, sincerely appreciate it.
Posted : 03/04/2016 6:33 am
IIRC That's actually functionalism, not brutalism though.. 😉
Posted : 03/04/2016 9:16 am
no problem Benz - I've got it back from the spiders!
I'll post it tomorrow.
Phil
Posted : 03/04/2016 1:52 pm
On that note, if anyone else has an adaptor floating around their garage they'd like to sell, I'd love to get one as well for an older frame I have and still use occasionally.
Posted : 03/04/2016 4:06 pm
Used one for years on a Zaskar, you might have to 'adjust' the brake mount a tad to get it just so, but it reads like you might be up for a bit of fettling .
Good to see some finished pics, a ti frame for a 10yr old girl sounds absolutely bloody marvellous. 8)
Posted : 03/04/2016 7:35 pm
