A SSers opinion on ...
[Closed] A SSers opinion on derailleurs.
40 Users
I know I often give the impression that I'm anti-gears, but in reality I don't think there's anything wrong with gears.
However I think the implementation of gears, ie derailleurs on an mtb is very limiting.
They're fine on a road or gravel bike, but far too exposed for UK mtb conditions unless you stick to the manmade mtb trails.
Any time I say that I get howled down and told how reliable they are, yet every StrathPuffer I do I usually pass one poor soul every lap with a busted derailleur (it's about the only time I get to pass anyone 🙂 ).
Occasionally on the odd group ride I go on, someone will belt his derailleur against a rock which usually fubars it, but it usually can be bodged to get home. Worse is to get heather entangled in a derailleur and if the rider isn't savvy enough to recognise the symptoms and stop in time, it takes out the derailleur and spokes.
Derailleurs are a well perfected mechanism for efficiency, so I don't see them replaced by an alternative system soon (I use hubgears when I want some spare ratios), but they hang where they get a continuous spray of grinding compound aka mud, so drivetrains are regarded as consumables these days.
The problem really is a design issue. The manufacturers benefit from their systems being consumable, so there's no motivation to change to something more durable.
Some of the original derailleurs were safely tucked up against the chainstays. Surely this should be done for mtbs.
Then it would be possible to enclose the mechanism to a certain extent, and get a much longer lifespan.
What improvements to the derailleur can STW come up with?
Posted : 30/12/2020 8:27 am
Pinion?
I suppose with 1x systems and wide range cassettes you naturally end up with part of the derailleur very close to the ground which you don't get on road bikes. They (derailleurs) are certainly consumer items but I reckon on three to four years of a lot of riding out of each unless I prang one - which I haven't done "yet".
The only problem I can remember with anyone's derailleur on a group ride was a couple of winters ago when we were in and out of snow and someone's mech got iced up.
Currently derailleurs could be seen as the "least worst option"?
Posted : 30/12/2020 8:48 am
@whitestione the "least worst option" is probably right. 🙂
I suppose my thinking is coloured by my age. We expected a gear system to last the life of a bike.
But surely it is not beyond the wit of human ingenuity to make the mechanism fool proof.
Posted : 30/12/2020 8:58 am
In 35 years of cycling/biking/dicking around on bikes, I have never broken a derailleur, nor have I been on a ride with anyone who has. I’ve broken chains, chainrings, hub shells, axles, shocks, forks, saddles, but never a derailleur.
I’ve bent one in a serious fall on a road bike, but even that was literally pressed back into service, despite having several newly planed flat areas.
Posted : 30/12/2020 9:04 am
 Keva
Years ago when I didn't know much about bike maintenance I used to crash through derailleurs all the time. Nowadays they last me years. The one on my 2x10 set up is four years old and there's nothing wrong with it at all. A couple of other bikes I used to have are still running the old upside down reverse 9sp mechs so that shows you how old those are, a mate of mine now has the bikes and they're still running perfectly.
I used to ride SS xc years ago but found that it was impossible to ride up the short steep muddy slopes round our local trails in the winter time, not from it being too hard to pedal but from sheer lack of traction on the back tyre. Singlespeed on the road however is much better for me, so when I go xc riding it's gears and when I go road riding it's SS 🙂
As for improving derailleurs I'll leave that to the design engineers but I find they work perfectly if they're well looked after.
Posted : 30/12/2020 9:24 am
I'd like to see more development of a 5 to 7 speed systems, IGH or derailleur. Wide-ish ratio, bigger jumps accepted. Chain durability and general tolerances increased. Longer wear rates.
The old chainstay mount mech would suit something like this but it'd never take off on mainstream bikes. Some custom builders work with them still.
I've had a few mechs broken by stumps or rocks, one ripped off in muddy conditions, but all in all they're pretty good. Still, none of my bikes get expensive RDs and my winter MTB is a SS as 11-12T cassette sprockets and RDs struggle to cope in the clag. It's in winter that exposed, complex drivetrains can seem ridiculous.
My perfect XC MTB or touring bike would use a really high-end 3spd IGH - light, efficient and direct with wide ratios.
Posted : 30/12/2020 9:37 am
James - I take it you've seen Box Components drivetrains? They do 7spd, 8spd and 9spd drivetrains.
Posted : 30/12/2020 9:46 am
I usually go for donkeys without breaking one, then have a spate.
A few years back I lost about 3 in fairly quick succession, then nothing until the other day where a twig mangled one.
They've always broken from stuff getting thrown up like rocks and sticks, never from actually bashing into something.
They're a consumable but not one I worry about constantly, so it's a meh from me.
Thinking outside the box, why don't we fit them upside down on the top of the cassette? That'd work. 😉
Posted : 30/12/2020 9:54 am
I suspect if everyone had gearbox bikes then you'd be passing someone with a broken gearbox. If everybody rode singlespeed you'd be passing someone with a snapped or thrown chain.
Posted : 30/12/2020 10:03 am
They’re fine on a road or gravel bike, but far too exposed for UK mtb conditions
Not really. I've broken one in 30 years on a twig (I think) and one in a freak accident caused by badly worn 3rd party jockey wheel bearings - on road.
All the available drivetrain configurations have downsides, what are you gonna do? There may be some idea from way back that could be brought back, but I'm not hopeful.
Best option I reckon is the Shimano patent.
If everybody rode singlespeed you’d be passing someone with a snapped or thrown chain.
Or a hell of a lot more people pushing up climbs.
Posted : 30/12/2020 10:04 am
My perfect XC MTB or touring bike would use a really high-end 3spd IGH – light, efficient and direct with wide ratios.
As someone who has used one gear for the last 20 years I tend to agree as if I wanted gears I would just want one that matches my current single speed gear and be used for majority of time with just one lower for steeper hills and one higher for high speed flat and downhill. I appreciated that my riding has clouded my view but why people need 12 gears doesn't make much sense to me as I have managed with 1 for all this time.
Posted : 30/12/2020 10:06 am
Whitestone, yes, though they're DH ratios not wide range. Microshift also making 8 and 9s though aimed at entry level 1x. SRAM's E-bike 8s system is on the right lines. E-bikes could be the driver of these ideas so that the niche XCers can get what they want, whereas on our own the market just isn't there.
Posted : 30/12/2020 10:07 am
Bit clickbait this one. Mechs rarely cause problems and offer a wide ratio with low weight. Such a good solution it's kept being improved for the best part of a century, rather than made obsolete. SS is a conscious choice for various reasons, but not an alternative.
Posted : 30/12/2020 10:13 am
Same here. Ever since my first Exage 6 speed gear system in 1987 I’ve never broken a rear mech or even bent one. Ridden all over the country and currently ride most in the Peaks area which is very rocky.
I’ve also never snapped a chain nor bent a front mech. Bent wheels, forks, pedals, frames but never had an issue with drivetrains. Even when I had a SRT500R Gripshift in 1995!
There’s a reason they are still around. Easy to use, reliable and very efficient. All other options seem to be a solution looking for a problem.
Posted : 30/12/2020 10:20 am
I kind of get where the OP is coming from. Mechs just don’t seem very elegant from an engineering perspective. Similar can be said of telescopic forks, but in reality both work really well, possibly due to years of development to try to run out the inherent problems. Every so often somebody try’s to invent a better mousetrap, but guess what, nothing better has been found yet!
I appreciated that my riding has clouded my view but why people need 12 gears doesn’t make much sense to me as I have managed with 1 for all this time.
Where do you ride most? No matter how fit you are you’d be walking a fair bit in some of the steeper parts of the country!
Posted : 30/12/2020 10:22 am
I always think the alfine 8 was near perfect for me off road but then remember that the shifter and it's massive window didn't fit nicely with all brakes, getting the wheel in and out was always a faff because you needed a 15mm spanner and to unhitch the cable, it was quite weighty and you'd need a tensioner if you ran it on 99% of full suspension bikes.
I still have two Alfine which will end up on commuter bikes but unless on a very specific hardtail I don't think I'd use them off road again.
Posted : 30/12/2020 10:23 am
Mechs rarely cause problems and offer a wide ratio with low weight. Such a good solution it’s kept being improved for the best part of a century, rather than made obsolete. SS is a conscious choice for various reasons, but not an alternative.
Totally agree. They're refined, efficient and can be relatively cheap. Ride-ending failure is rare. SS is a fix for some conditions but comes with greater compromises (as much as I like SS).
imho it's a shame that the IGH alternatives have mostly tried to replace the range -and with it, weight- that derailleur systems have, rather than offer something that's a half-way between the durability and efficiency of SS and the range and efficiency of der. gears.
I liked it for a while. Was a very good option esp with tubeless making wheel removal rarer. But the weight concentration was a drawback that influenced the ride too much for me.
The Nexus 3spd shift joint would be vulnerable on an MTB but it's a great system for easy wheel removal.
Posted : 30/12/2020 10:25 am
Didn't we have virtually this same post from the same OP about 6 months ago?
I don't have a problem with derailleurs.
I've bent one in about 24 years of riding bikes with gears. And that was bent back to give me options for riding home.
If something genuinely better came along that fulfilled the myriad of criteria, then it would have done by now and be widely adopted.
An enclosed gearbox would be great, but don't think we are there quite yet for mainstream uptake.
Posted : 30/12/2020 10:52 am
Didn’t we have virtually this same post from the same OP about 6 months ago?
Maybe, I probably said the same things about IGHs then too. And it'll keep coming up while some of do find drawbacks in what's currently available or see opportunity for development - while accepting that for many it's all fine as it is. Same can be said for suspension really.
Posted : 30/12/2020 11:00 am
+1 for three-speed bikes
12 really isn’t necessary on an mtb.
And nearly everything you need a 50 or even 36 tooth cog to ride up will be quicker and easier to walk up anyway.
Speaking as a racer.
Posted : 30/12/2020 11:15 am
This. Derailleur in a box FTW. Proven tech, protected and out of the way, better weight distribution.
Posted : 30/12/2020 11:17 am
It's not that hard to dream up potential improvements to most things, but making it cost-effective is a totally different thing. A basic Deore derailleur is fairly cheap and versatile, and most people go years without wrecking them. The current alternatives are hub gears and frame mounted gearboxes. Both are more expensive and less versatile than derailleurs. A derailleur-in-a-box gearbox mounted in the frame would probably be as efficient as a derailleur system, but regular gearboxes are not as efficient, so the XC end of the spectrum won't use them. A frame mounted derailleur gearbox system would be heavier and more expensive than a normal derailleur and it would have to be absolutely reliable because you would not be wanting to have to open it up out on the trail to unjam it if you messed up a gearshift.
Shimano, SRAM, etc. all have engineers who spend their time trying to figure out how to improve these things, it's quite likely that they will already have investigated any ideas posted to this forum and rejected them as either impractical (enclosing a dropout mounted derailleur, for example) or too expensive (gearboxes).
Posted : 30/12/2020 11:18 am
I do notice when on the SS that I'm far more confident in line choices knowing there isn't a rear mech that has to clear through the gap I'm leaving for the back wheel.
Also, I've not smashed my GX yet, but I went through numerous SRAM mechs in a single summer back on 10speed. Went back to Shimano and had zero trouble. So I've always gone with Shimano whenever possible. I presume I smash them into things just as often, but they seem to last better.
I end up treating gears as a tool for big days out, like a camelback. I'll take the SS (and a water bottle) for a ride that I can manage it on. And take gears for anything bigger.
Posted : 30/12/2020 11:20 am
Many moons ago, when I was deep into rigid SS long distance riding, I used to loathe derailleurs for the very same reasons as the OP. Then I came to realise 2 things:
- a massive percentage of RD failures are related with bad limit screw adjustments
- what I really hated were front derailleurs.
Nowadays I'm riding stupid stuff much more often but I can't remember the last time I had a RD issue. Today they have smaller profiles, bike's BB are much lower which make the pedals sort of a barrier ahead of derailleurs and 1x12 drivetrains are a thing of marvel
Posted : 30/12/2020 11:23 am
I quite like the mechanism for the bromptonderaileur.
Having said that i also wuite like the campagnolo? One where you have to undo the wheel with a lever on the seatstay then the wheel walks back on the toothed drop out. Might be interesting mid offroad climb.
Posted : 30/12/2020 11:25 am
You could always fit one of these if you're smashing them off regularly.
You might struggle to get through gates mind.
Posted : 30/12/2020 12:01 pm
No problems with derailleurs? I probably shouldn't have mentioned SS, then the response would be more like:
https://singletrackmag.com/forum/topic/poor-ground-clearance-on-xt-12x-mech/
@stump01 probably. This time it was triggered by seeing one of those dinner plate rear cogs and the derailleur hanging so close to the ground.
Posted : 30/12/2020 7:22 pm
Epi are you saying your non derailleur bikes have clean chains at all times?
And...as above...in 33 years riding off road (less these days admittedly, and no 1x yet) I've mangled 2 mechs (one on @leffeboy 's bike 😀). I don't recognise your experience, although it does seem more of a thing these days, I blame lack of care and subsequent hangers.
Posted : 30/12/2020 7:51 pm
cynic_al
I don't think I claimed to have a clean chain.
Only on my full chaincase bikes. The life on those is measured in decades.
I rarely clean my bikes, although chains do get lubed.
@jameso I agree. My ideal would be a very wide ratio 3 speed with close to the range of an Alfine, or a 5 speed with the range of a Rohloff. Three speed for preference because it would be lighter (a 3 spd S-A hub is about 990gms.
Posted : 30/12/2020 8:01 pm
I once inverted my bike to do something, and then wondered- why isn't the derailleur mounted above the wheel rather than below? It would prevent rock strikes, and with modern clutch mechs the tensioning issue is gone.
In fact, with thru axles, the need for a dropout below the axle/QR, rather than above, is also removed.
1 x systems and huge dinner plate cassettes are making it more of a problem than before, of course.
Posted : 30/12/2020 8:49 pm
 Del
TBF this one makes a refreshing change in my view. unless an independent scotland is going to outlaw derailleurs 😉
jameso + 2
i feel that at least half the gears available these days are just there to make getting from one useful one to the next easier.
Posted : 30/12/2020 9:07 pm
 LAT
I’d like to see more development of a 5 to 7 speed systems, IGH or derailleur. Wide-ish ratio, bigger jumps accepted.
i was looking at the 9 speed wide ratio cassettes in the hope that they’d be lighter than 11. they are not. pretty obvious when you are only loosing a couple of sprockets.
@jameso how many teeth would you want the lowest sprocket? or you had a 50 would you still not need a mech with the same dimensions?
Posted : 30/12/2020 9:24 pm
I loved my Alfine 8, until it died.
It had been abused on an MTB for years, and I'd gone way lower than recommended sprocket wise, so it was a valiant effort from the poor misused hub.
But hell yeah, a lightweight, wide ratio 3spd IGH please!
Posted : 30/12/2020 10:18 pm
My rear mech iced up today, has happened before when riding in snow, bit of a pain. I've also broke a couple on rocks but have bent or broken countless mech hangers over the years.
I think they're a crap for proper off-road especially in muddy conditions but they do work well enough for a decent amount of time.
Next mountain bike will very likely have a gear box.
Posted : 30/12/2020 10:27 pm
ye olde sturmey archer? I run one and its great. Only 50 years old. 200% range IIRC
I have to say that having a mix of bikes half with IGH then its always a bit of a retrograde step for me to get on a derailleur bike. No shifting when stationary, slappy noisy chains. the silence when running a IGH is really noticable
Posted : 30/12/2020 10:29 pm
alfine 8 is a couple of hundred quid. what the cost of a deore hub, mech, levers and cassette? Also don't forget running costs are virtually zero with an IGH
Posted : 30/12/2020 10:32 pm
Bit clickbait this one. Mechs rarely cause problems and offer a wide ratio with low weight. Such a good solution it’s kept being improved for the best part of a century, rather than made obsolete. SS is a conscious choice for various reasons, but not an alternative.
Not clickbait imho -only yesterday I ripped off a 12 speed mech by simply trying to climb up a narrow sheep track through some heather. I’ve done it before too snd a riding mate of mine avoids such terrain for just this reason.
Singlespeeds have their uses and scratching around through heather is one of them.
Posted : 30/12/2020 10:45 pm
I don't find that to be the case. You'd just adjust your gear for climbing. As a general rule i'll get up anything a geared bike can and often faster as theres not much choice how fast you go. When i do get off and push geared bikes will be giving up or i'll pass them on foot.
I'm not a heroic singlespeeding god or anything its just not as hard as people think! What will catch me out os very tight steep hairpins, thats technique that i just really struggle with for some reason.
Posted : 31/12/2020 7:51 am
I think big low hanging wide range 1x systems just exacerbate the flaws of rear derailleurs, I've never had so many drivetrain issues as when I switched to 1x 11-40...
I think the real genius would be solving whatever issues it is people have with front mechs, then shifting all that weight and clutter back away from the rear axle.
Were internal geared cranks really so awful?
Posted : 31/12/2020 8:11 am
why isn’t the derailleur mounted above the wheel rather than below?
Because it needs to guide the chain into the sprocket. The front derailleur is mounted on top, the rear derailleur is mounted below because that's where the chain is fed into the sprockets. If you wanted to only have a top mounted derailleur, you'd need to squeeze 12 sprockets into the bottom bracket area. The top part of the chain is under tension, so shifting under power would be a problem. You'd still need a tensioner somewhere under the chainstays because that's where the slack chain is. If you want to move the derailleur away from under the dropout, the only realistic thing to do is to enclose it and use it as a frame mounted gearbox, which is not a new idea.
Posted : 31/12/2020 8:16 am
@tjagain. Alfine IGH isn’t a great solution for modern bikes though as it requires a QR rear end and doesn’t particularly like high torque. Not many frames are QR these days and whilst you can change gear standing still on an Alfine, they don’t like shifting under heavy load and can slip if you try. Not ideal for a MTB.
Posted : 31/12/2020 9:20 am
13 or 14T - any smaller and I've had problems with jamming and skipping in winter. And it always seems daft to build in tighter radius sprockets. I'm not too worried about top-end gears anyway.
13-40 across 6 gears would have gaps like a double shift on an 11-34 cassette. That would work OK.
I'd like to see narrower freehubs to go with it, for less chainline variation and stronger rear wheels. I have a Jeff Jones mod rear wheel on one bike, a Hope SS hub with 6 9s sprockets on it (15-32 or similar) works well with a double on the front - all the range needed for bikepacking and no problems cross-chaining, you can use all 12 gears with a good chainline. I don't get the full gear range available from a 1x12 but it's not far off, close to an 11-42 1X. A wider ratio rear i/o a cut down XT 9s would fix that.
Posted : 31/12/2020 9:29 am
Funny you should say this, I've been riding my road bike 'fake SS', not shifting for most of a ride looking for a good SS ratio for a new build. Accepting that spinning out on the road is more dull than same situ on the SS MTB. Thinking about using an FD with a BB arm tensioner for 2 rings up front, ie 48T main gear and a 36T bail-out. Gives me a gear I can push most of the time, and a gear that means a ride in a hilly area won't be impossible. Wales might be a bit too much o/c.
No logic to it, just I like riding SS (ish) and this may be a simple, long-distance worthy way to get that direct feel. Wouldn't work so well on MTB if it needed a BB-mount tensioner though, can see that being equivalent to an RD.
(anyone done this and found a good BB mount tension method? I have a fiver on @epicyclo having done it)
Edit, like this > https://clee-cycles.co.uk/P1677/product
Posted : 31/12/2020 9:44 am
If you're smashing through gears and brute forcing the chain then that's 100% poor technique, not the fault of the IGH. Learn to change gears smoothly and all drivetrains will improve.
Posted : 31/12/2020 9:49 am
Thols2 understands properly how rear mechs work - saved me some typing 🙂
And if you watch a muddy cross race, you'll understand how a lot of rear mech failures occur. It isn't from impact - it is from something in the system getting sticky or jammed and then dragging the mech. So that can be all kinds of things:
Stuck freewheeL
Seized or jammed jockey
Twig
Tight chain link
Bulging open chain link
Chain suck / sticking to the underside of the front ring
I'm commuting 7 miles each way on Alfine. That will change to 20 miles with a house move in summer. Just starting on a new commuter frame which will probably keep the Alf (although I do have a totally inappropriate desire to make a single sided / righty Gates ss frame).
Have a disc mount 135 Sturmey in the attic - weight and efficiency are OK, just a weak axle and non existent sealing stops it getting more use. I did swap some emails with Alan at Sunrace 10yrs ago, but he could never see there being a market for mtb 3 spd.
Love ss and need to go back for mtb duties sometime. I've got two drawbacks - slow and cold on long flat / roadrunner sections. And it used to work great riding with the kids, but now eldest is proper u23 xc race fast, I get left behind EVERYWHERE unless the terrain is just right.
Just out to play in the snow so pray for my mech...
Posted : 31/12/2020 9:50 am
@jameso I looked into something similar but at the time couldn't find a sprung front tensioner that would accommodate the double chainring width.
Posted : 31/12/2020 9:52 am
I never had any of those issues with my alfine. I think much of the issues people get with alfines are due to lack of maintenance.
No problems with high torque - I ran mine at the puffer on stupidly low gearing with no issues
Posted : 31/12/2020 9:54 am
(anyone done this and found a good BB mount tension method?)
Tried a few and not found one I like.
I think the two jockey wheel rear tensioners are a better solution - Rohloff, Paul's, Alfine are the 3 I can think of.
No problems with high torque – I ran mine at the puffer on stupidly low gearing with no issues
I ran mine with a 30 front and 22 rear. Way outside the recommended gearing.
Gave it an oil dip once a year, and it ran fine.
It did eventually die catastrophically, but it gave good service while it was alive!
Considering I bought it for £100 second hand and ran it for 5-6 years I was happy.
I think the two jockey wheel rear tensioners are a better solution – Rohloff, Paul’s, Alfine are the 3 I can think of.
They would be better/easier, I suppose visually I'm after a clean rear wheel and dropout area and moving the mechanicals to the chainset. A bit like a 30s Bianchi.
Posted : 31/12/2020 10:07 am
I think my puffer gearing was 26 front and 22 rear. Might have been lower.
Posted : 31/12/2020 10:08 am
Also don’t forget running costs are virtually zero with an IGH
So, are they low maintenance or high maintenance? 🙂
Posted : 31/12/2020 10:15 am
😲 Impressively low!
If you're happy taking out the internals once a year to dip in oil, then I'd say low maintenance.
Some people wouldn't like it though. Involves cone spanners and ball bearings.
Posted : 31/12/2020 10:16 am
Low maintenance - annual dip in atf. Takes about 20 mins plus a while sitting in the bath 🙂
Edit - a single cheap chainring and a single cheap rear sprocket - and they last much much longer. I also like the silent running.
I also have a rohloff and a SA 3spd
MY puffer gearing effectively worked out similar to a 9 spd 2x setup but only the granny ring ratios. span out about 12 mph
Posted : 31/12/2020 10:18 am
jameso
You're right.
About 22 years ago. The BB mount tensioners were enjoying some popularity amongst the DH crowd in my area and I saw it as a possible solution to tensioning a SS chain on an MTB frame with vertical dropouts. (For some reason they weren't making MTB frames with proper dropouts back then 🙂 )
The drawback I found was that I could make it slip out of adjustment under pressure. I didn't persevere with it because a frame with proper dropouts came on the market so I imported that (thanks to Surly for the 1x1, still riding it).
I reckon it would work better if the tensioner had a spring mount. Alternatively a bike frame the ISG mounts on the BB shell rather than rely on the clamping action of the BB against the shell.
My solution was Magic Ratio. It works pretty well, all you need is three cogs, one on each side of your ideal. Even better if you want to fine tune is a couple of chainrings, eg 33 and 32. That way, you'll find a combo that works and isn't too tight or too slack. I use steel chainrings to avoid wear. A properly set up SS chain can tolerate a lot of slack so wear isn't a problem (especially with steel rings).
Always remembering, it's not worth obsessing about getting the perfect ratio in SS, close enough is good enough. We're in the wrong gear 90% of the time anyway. 🙂
Posted : 31/12/2020 10:20 am
I've also got a Nuvunci hub that I've experimented with on my Krampus.
460% gearing, continuously variable gearing via a twist grip.
It's a great concept, but...
a) very heavy.
b) very draggy in the lower gears.
Posted : 31/12/2020 10:21 am
My fiver was safe : )
That's it, something like the Yess tensioner I found with a mod so the roller/JW could slide to account for 2 rings with a 10-12T gap. Might be a DIY job for the new year, got a load of old DH BB mount stuff that may help. The 2 rings + FD with SS rear idea appeals and could make a nice bike.
30s bianchi
Posted : 31/12/2020 11:18 am
 Del
my eyes!
Tom - spare alfine hub sitting in my garage with all the kit doing nothing. open to offers... 😉
weight in the wrong place for MTB IMO.
Posted : 31/12/2020 12:23 pm
So just like all normal gears have their weight in the wrong place then?
https://singletrackmag.com/forum/topic/stu-mcgroos-lets-put-this-alfine-weight-issue-to-bed-once-and-for-all-thread/
Posted : 31/12/2020 12:31 pm
@Del
I'm running out of bikes an Alfine will fit on.
Of the bikes I'd want it on only the Krampus doesn't have a thru axle.
Posted : 31/12/2020 2:20 pm
epicyclo you originally said
Derailleurs ... hang where they get a continuous spray of grinding compound aka mud, so drivetrains are regarded as consumables these days.
Implying that your non derailleur bikes don't hence my previous comment.
Not meant at all personally tj but there are no climbs there that are even remotely steep, so I can't see that as high torque for the hub.
Otherwise I quite like the idea of fewer gears with bigger jumps, so many benefits, and unless you are racing you don't need to be in the perfect gear IMO.
Posted : 31/12/2020 5:26 pm
 LAT
@jameso ah, using a 2x!
how would you feel about the return of the hammerschmidt or something similar?
this always seemed like a good idea. would be good with smaller cassettes and wider flanges.
Posted : 31/12/2020 6:37 pm
I found the chainstay mounted Suntour mech that removes a bit of the clutter behind the axle. Even has the indexing in the mech not lever.
http://www.disraeligears.co.uk/Site/SunTour_S-1_derailleur_S100.html
Alfines don't shift under load, but they do keep going in your existing gear without complaining (the shift just happens once unloaded).
@mick_r
Interesting website. This page says that Shimano started out making derailleurs then switched to hub gears, then went back to derailleurs to increase the range of the hub gears, then started selling derailleurs as a stand alone product. It was the Tourney that conquered the world, introduced in 1967 as the Skylark.
http://www.disraeligears.co.uk/Site/Shimano_derailleurs.html
Posted : 01/01/2021 3:02 am
Not meant at all personally tj but there are no climbs there that are even remotely steep, so I can’t see that as high torque for the hub.
its the overall gearing you run that effects the torque thru the hub - not the steepness of the climbs
Posted : 01/01/2021 8:05 am
This is just click-bait crap, and you know it. if you want to have a discussion about gears, go for it, but like Daffy in 30 years + of riding everywhere, from the alps to Moab, from the Chilterns to Calderdale and Scotland I've never bust a mech, so I guess any issues you have with them is user failure.
Anecdote is not evidence.
Derailleurs are a well perfected mechanism for efficiency, so I don’t see them replaced by an alternative system
Rohloff have been doing nothing but trying to develop a hub gear for 25 years now, it's still too heavy, too complex and not user serviceable. It's totally unfit for purpose. If hub gears, like other forms of front suspension were going to replace what's there already, it would've happened. It hasn't because:  Le mieux est l'enemi de bien (as Voltaire probably didn't say)
but they hang where they get a continuous spray of grinding compound aka mud, so drive-trains are regarded as consumables these days.
Everything from the chain to any gear system you put on the back of a bike is going to get covered in spray...(correlation is not causation)
The manufacturers benefit from their systems being consumable, so there’s no motivation to change to something more durable.
That's because derailleurs are durable, I've never bought a mech. to replace a broken one, and that's the experience of most folk. That you ride with folk who've broken them is conformation bias, there are millions; literally millions of mechs in the world being perfectly happy
Teaching people how to ride? your issues with them are clearly user based..You trot out your personal ennui every few months Come up with something else to grumble about, (old men, sky, shouting etc etc)
Posted : 01/01/2021 8:24 am
Rohloff have been doing nothing but trying to develop a hub gear for 25 years now, it’s still too heavy, too complex and not user serviceable.
If you browse about that website that mick_r linked to, it says that Shimano started out making derailleurs then introduced hub gears (for commuter bikes) and stopped making derailleurs. Then they started making derailleurs again and dominated the market because they made an affordable, reliable derailleur for touring and commuter bikes. This goes back far before Rohloff, and hub gears have long had a solid niche market, but derailleurs are simple and cheap to manufacture and are good enough for most people. I've bent a couple of derailleur hangers and destroyed one derailleur in 20 years. It's so infrequent that it's not a big problem.
Posted : 01/01/2021 8:37 am
I'll not be buying a Rohloff, but the "not user serviceable / unfit for purpose" is stretching things a bit far. Do you do much servicing of your car gearbox? I used to have a fun leg-pull with an old engineer at work who was a Sherpa van fan whilst I ran fwd Citroën vans:
Q "How do you easily reshim the differential on your fwd French cr@p?"
A "In hundreds of thousands of miles the diffs have never needed reshimming...."
Ironically he now owns a VW T5, one of the fwd vans most prone to diff / driveshaft issues 🙂
Posted : 01/01/2021 11:15 am
How about a non-epicyclic hub gear? Pear shaped flanges with multiple spoke lengths would be fun.....
[url= https://i.postimg.cc/zGq4KQQg/20210101-111823.jp g" target="_blank">https://i.postimg.cc/zGq4KQQg/20210101-111823.jp g"/> [/img][/url]
Posted : 01/01/2021 11:26 am
 hugo
I’d like to see more development of a 5 to 7 speed systems, IGH or derailleur. Wide-ish ratio, bigger jumps accepted. Chain durability and general tolerances increased. Longer wear rates.
I wholeheartedly agree. The whole "progression" being based on number of gears causes compromises elsewhere.
It's a bit like all new cars having to having to have 24 valves or 7 seats just because they can.
There's a definite need for a rock solid and quality 7 speed system. I'd even like to see a modern version of a 3 speed wide range hub gear.
We've already got rid of 3x and 2x is going....
PS. I like gears!
PPS. A big issue with having bombproof derailleurs is that when they get a clang the frame can end up taking the brunt of it...
Posted : 01/01/2021 12:02 pm
but the “not user serviceable / unfit for purpose” is stretching things a bit far.
Rohloff insist on servicing their hubs*, there are no user serviceable parts and going through hub deep water is "extreme conditions" as per their warranty...SFB, (recently departed of this forum) had to send a hub back to Germany twice after some river crossings in the Lake district. They admitted to him that it wasn't sealed well enough not to ship water and fail. For an apparently off-road suitable product that for me falls into "unfit for purpose". My derailleur has never failed to work because it's got wet...
* and you need to ship it there at your own cost...Good luck with that now we're out of the EU.
Posted : 01/01/2021 12:14 pm
While everyone here is waiving their penis around telling each other they are wrong, I'd just like more choice.
I don't care if rear mechs are prone to smashing or hubs feel like riding through treacle, I'd just like a bit more variety and choice when it comes to the bit between pedals and rear wheel.
Posted : 01/01/2021 12:48 pm
its the overall gearing you run that effects the torque thru the hub – not the steepness of the climbs
It's both and also how much W you put through the hub.
I still dont see the Puffer as a reliable test.
Posted : 01/01/2021 12:54 pm
I’d just like a bit more variety and choice when it comes to the bit between pedals and rear wheel.
Basically this.
Posted : 01/01/2021 1:09 pm
The whole “progression” being based on number of gears causes compromises elsewhere.
All engineering involves compromises. A 7 speed cassette cannot have the range of a 12 speed without having much larger gaps between the ratios, so engineers have to decide which compromise is better. A 3x7 system would allow a stronger rear wheel and give good range with small gaps between ratios, but having a front derailleur is a compromise. 29" wheels have benefits over 26" wheels, but they are difficult to package with a front derailleur, so 1x12 provides a better gear range than 1x7 would without needing huge gaps between ratios. Any choices you make like this involve compromises, with cost being a major one. There's no point making the best system in the world if nobody can afford it.
Posted : 01/01/2021 1:18 pm
A light-ish 3 speed hub would be lovely please.
For a lot of people that'd be ok, I reckon. Maybe even 5 speed would be ok. Like, if I've got gears on my bike I'll tend to leave it (10sp) in 7th which in my case is a singlespeedy sort of gear and maybe wiffle up or down a gear depending on what the road or path's doing or I'll just dump it right down to the bottom gear if I'm knackered (or get off and push!)
Posted : 01/01/2021 2:15 pm
There’s a definite need for a rock solid and quality 7 speed system.
Really? Surely 11sp is rock solid and quality?
Posted : 01/01/2021 2:28 pm
Based on only my experience, a nice 5-7 speed would suit ebikes. Think the last one I borrowed I only used 3.
Posted : 01/01/2021 7:25 pm
@Jameso I used that Jones mod for years, originally with an XT 34t cassette and an old Shimano 600 derailleur then found Sunrise do a wide range 8sp cassette which when split and replaced, gives you 13-34 or 15-40. The cogs are even 10sp width, so could probably be spaced 7 at 10sp spacing.
I've recently gotten a modern bike with SX and I'm seriously unimpressed with it, which may be me, mud or general wintryness.
Posted : 02/01/2021 9:08 am
And 12 sp. to be fair, mines be totally reliable (as was the 7, 8, 9, 10, and 11 speed that proceeded it)
Posted : 02/01/2021 9:41 am
