A quick rear hub qu...
[Closed] A quick rear hub question.
4 Users
If my rear hub axle states it's M12 x P1.5 Length 171 - could you kindly advise this idiot what rear hubbed (I'm buying a factory built wheelset) wheelset I need to order?
Thank you
Posted : 29/05/2020 11:10 am
No, you can't tell from just that measurement. You need to know the spacing between the dropouts which will be either 142 (older standard, pre 2016-17 ish) or 148mm (Boost standard). The length of the through axle depends on the frame as well as the hub.
Posted : 29/05/2020 11:17 am
what's the frame?
Posted : 29/05/2020 11:19 am
Thanks for the replies. It's a Wilier 503X. Pretty sure it's not Boost. Front is 100m, 15mm Thru Axle. The Willier website isn't much help.
Posted : 29/05/2020 11:30 am
Taking more riders off-road and into the mountainsThe 503X is the complete redesign of our flagship aluminium hardtail. We rethought the details, and tested the bike on the best MTB trails in the Dolomites. The 503X meets the needs of a wide mountain bike audience, getting more people off-road and into the mountains.Available in three colors and three specifications COMP, PRO and RACE, the 503X is an MTB hardtail that enhances value for money. Featuring 29 inch wheels and 100 mm of fork travel.The 6061 double butted aluminum frame incorporates the latest advances in the offroad field:- Tapered Head tube: 1 ½" bottom, 1 ⅛" top
- Integrated cables
- Press fit bottom bracket 92 mm
- Seatpost 27.2 mm diameter
- Direct mount Derailleur
- Thru-axle rear dropout: 142 x 12mmThe 503X is available with 29" wheels in 4 sizes: S, M, L, and XL.
Taken off https://wilier.com/en/my2020/int/endurance-bikes/mountain-bikes/503x-comp
so looks like 142 so older standard hub and NOT Boost
Posted : 29/05/2020 11:33 am
Thank you for the help. I couldn't find my year model on the Willier website and it refers to "updates" and "upgrades" which was making me doubt what I was reading.
Posted : 29/05/2020 12:50 pm
