A question about cl...
[Closed] A question about clutch rear mechs
12 Users
 dday
I understand the principle behind these clutch systems, and it seems to make a lot of sense. I notice some systems (SRAM) have the clutch engaged permanently, while others (Shimano) it's a toggle.
What I don't understand is the apparent ability to engage or dis-engage the clutch. When would I do this? Before a downhill? Before an uphill? Cross country? When my bones tell me chain slap is imminent?
Posted : 01/03/2013 9:21 am
When you're taking the wheel out - just makes it easier.
Posted : 01/03/2013 9:22 am
on shimano its so that you can remove the rear wheel and slacken the chain (e.g. when using the powerlink?)
Getting wheel in and out can be easier with it 'off'.
Posted : 01/03/2013 9:23 am
I keep forgetting about it, it doesn't really make that much difference when changing wheels tbh but it [i]is[/i] easier with it off.
I've a feeling a major reason is so you can flick it on and off and do an a/b test and go "this is AWESOME!" 😆
Posted : 01/03/2013 9:28 am
the sram clutch mechs have a little button for taking the wheel out, basically it locks the cage forward taking the tension out of the chain. its ace!
Posted : 01/03/2013 10:10 am
 dday
It all make sense now, thanks!
Now before a downhill, I can:
1. Drop my post
2. Turn off pro-pedal
3. Open full travel on Talas fork
4. Adjust compression ration
5. Dissengage lockout
6. Flick rear mech toggle on and off and do an a/b test and go "this is AWESOME!" 😀
All this stuff MUST make me a better rider! 🙄
Posted : 01/03/2013 11:29 am
the clutch is on all the time when riding not and on/off depending on terrain
Posted : 01/03/2013 11:39 am
Yep, no actual reason to switch it off while riding, it's not a "descend mode" thing like propedal etc.
Posted : 01/03/2013 12:34 pm
I generally don't do any of that list of 6 when doing a downhill, unless it's a PROPER downhill in which case the saddle goes down, but forks and suspension stay setup active 100% of the time!
Posted : 01/03/2013 12:48 pm
Nice thing with the shimano clutch is you don't have to have it fully 'on' or 'off', as it will stay put anywhere in between, so you can adjust the degree of chain slap reduction vs. heavier shifting to suit, without recourse to taking the cover off and tweaking its nuts with a tiny spanner. 😉
Posted : 01/03/2013 1:26 pm
It's a little bit more than that: If you don't turn it off you might knacker the clutch. It's not really optional, just do it. 🙂
Posted : 01/03/2013 1:39 pm
Really chives?
I'm gonna test that out this arvo!
Posted : 01/03/2013 1:45 pm
 ojom
1. Drop my post
NOOB
You forgot
7. lower tyre pressure
8. Start GOPro
9. Start Strava
Posted : 01/03/2013 1:47 pm
You forgot checking that your wheels are secure and your brakes are both working!
As said above, It's not something you turn on and off on the ride. 🙄
Posted : 01/03/2013 2:01 pm
Northwind - Member
I bet Scott have a bike with a remote on the bars for it though.
Posted : 01/03/2013 2:44 pm
