A bit old skool.......
[Closed] A bit old skool..... rear QR question
4 Users
I've got a CX bike which is QR all round, perish the thought I hear you say, the wheels will fall out Guv, it can't be stiff etc etc.
But in all seriousness, its QR135 rear and has mis-matching QR's will a 130mm qr be ok, or does it have to be a 135?
Posted : 18/12/2019 4:20 pm
I wouldn't and I'm not sure many will say they would. Imo a pair of Shimano qr are cheap and as good as any if not better.
Posted : 18/12/2019 4:25 pm
So long as the thread on the QR axle goes all the way through the threaded bit of the nut it'll be fine.
(in most cases for max strength, a thread needs to be engaged by its own diameter into a nut - eg a 5mm bolt needs a 5mm deep nut. If you're dealing with an alloy nut on the end of the steel QR axle, you'll want a bit more penetration to compensate for the weaker material)
Posted : 18/12/2019 4:53 pm
