9mm qr wheel to fit...
[Closed] 9mm qr wheel to fit 15mm fork
6 Users
As title says is it possible or is a new wheel required
Posted : 02/05/2014 7:30 am
Depends on the hub and whether its something like a Hope thats easily converted.
Posted : 02/05/2014 7:31 am
A above, it primarily depends on the hub design but also depends on the bearings used and the size of these.
What hub is it? Someone may have done the conversion before.
Posted : 02/05/2014 7:34 am
No it's xt hub
Those in the know about shimano hubs will need the model number of the hub to determine if it is possible to convert it. I am not one of them.
Posted : 02/05/2014 7:37 am
I'm not sure why you'd need to convert the hub? If you use a 15mm to QR axle that should work - I've done this on 12mm to QR before now.
[url= http://www.chainreactioncycles.com/nukeproof-conversion-kit-15mm-to-qr/rp-prod80192 ]example here[/url]
This doesn't specify the length so would need checking, but it really isn't 'hub specific' - if it's 15mm diameter and the right length it would work.
Posted : 02/05/2014 7:52 am
example here
That's a hub conversion kit, for converting a Nukeproof hub...
Can't convert XT hubs sadly, new wheel time.
Posted : 02/05/2014 8:04 am
 core
Think you've got confused [b]phil56[/b], it reads to me that he has 15mm forks, but a 9mm hub, so that adapter would be the wrong way around, it would let you fit a 15mm hub to a 9mm fork.
Posted : 02/05/2014 8:05 am
In addition to njee's comments the OP is looking to got the other way, from the title any way it would appear that he has a 9mm QR hub and wants a 15mm hub.
Posted : 02/05/2014 8:08 am
Think you've got confused phil56, it reads to me that he has 15mm forks, but a 9mm hub, so that adapter would be the wrong way around, it would let you fit a 15mm hub to a 9mm fork.
Please ignore me - I'm old and it's early. Matron hasn't come round with the medication yet!
Posted : 02/05/2014 8:11 am
