Is it possible to buy 94mm BCD 4 bolt 32 outer + 22 inner tooth chainrings
why would you want a 32 outer and a 22 inner? a 22 will fit on the inner only, and if you use that and an outer it will not work. the gap between rings will be too great. You have to use the middle position.
FSA carbon cranks perchance? The only ones I've found have been from Gebhardt in the Czech Republic - special order required.
yea indeed they are FSA carbon cranks...did you order some from Gebhardt ? how much + are they anygood?
bump??
Yes, I ordered some and they are fine. Can't remember how much but they were relatively cheap (though my mind is probably clouded by wholesale).
anyone else got any info on above?
You don't trust me? Checked invoices and it appears I paid about £30 each - so probably more like £50 for you. I only ordered 34t with no ramps though.
