9 or 10 speed chain...
[Closed] 9 or 10 speed chainset?
4 Users
 PJay
I'm running an ancient XT Octalink chainset which has been in use for years(now on its third bike)on a 3x9 setup.
At some point it's going to need to be replaced with something more modern. I don't really want to upgrade the whole drivetrain to 10 speed in one go, because of the cost and because there's still life in my current drivetrain.
As I understand it 9 speed chainsets can be used with 10 speed kit and 10 speed chainsets with 9 speed. There are some good deals available on older Hollowtech II XT 3x9 chainsets but equally there are good offers on 3x10 chainsets. I'm not sure what makes a 10 speed chainset 10 speed but the only significant difference between 3x9 and 3x10 that I can see is a 44 tooth vs 40 tooth large ring.
So the chainset would be used in a 3x9 setup which will be upgraded later to 10 speed; is there a best option between a 3x9 or 3x10 chainset?
The other option of course would be to wait until things start to fall apart and upgrade the whole lot to 2x10 in one go.
Posted : 26/08/2015 1:56 pm
2*10 groupsets are much better value than a chain set only.I'd wait and upgrade the lot on one go.
Besides running a new chain set on an old chain could well damage the rings anyway.
Posted : 26/08/2015 2:52 pm
Doubt you'll notice any difference between your "ancient" XT and the latest XT, if I were upgrading to 10 speed they'd be the last thing I'd buy.
Shifters, chain, cassette, front and rear mech, then chainset IF it's necessary.
Posted : 26/08/2015 3:16 pm
Hi,
If you really MUST change into 10 speed change only chainrings.
Octalink BB will outlast any given external BB by miles and miles...
I'm using 105 octalink BB on my do-it-all bike (commuter, roadie, CX, gnarmac) and it is spinning buttery-fluid 3rd season, approaching 25k...
Cheers!
I.
Posted : 26/08/2015 3:24 pm
 PJay
I'm more than happy with my current chainset and not desperate to upgrade to 10 speed but recently I had to replace my wheels which had also done 8-10 years spread over 3 bikes as the rims were beginning to crack; it's more a case of that making me aware that nothing lasts for ever. There are no cracks that I can see in the crank arms but there may come the time when, for safety's sake, they'll need replacing.
Posted : 26/08/2015 4:55 pm
Haven't seen too many catastrophically failing crankset pics in the Web.
Especially that I'm still riding FC-M730 square tapered cranks from around 1990 on my single speed.
No problems whatsoever...
Cheers!
I.
Posted : 26/08/2015 7:33 pm
