I'm after a fork that's 80mm (ish) on min, and 120mm on max travel. Anyone got any thoughts?
Easy to find a 100-140mm, but not less. Help!
RS Reba u-turn?
Hadn't found those, thanks. Is there anything from the last few years if i decide to go the second hand option?
tora u turn [spring] was about that iirc but quite heavy and will be quite old now
If going 2nd hand, maybe ebay - rockshox psylo's. good fork and have the u-turn adjustment from 80 to 125
example - item number: 130512650007
I'd stick with the Reba's 2nd hand, older u-turn versions are 85-115mm, newer 90-120mm. Solid fork with good weight, decent performance & home servicable
