73mm B/B in a 68mm ...
[Closed] 73mm B/B in a 68mm shell...
7 Users
Purchased a new Isis BB the other day from Superstar. I was sure the shell was 73mm but no it's a 68. I've installed and now removed the new BB so won't be able to return it. Any how, with some spacers I should be ok I think plus I'm running single speed so chain line issues and shifting should be a problem..... Or am I wrong and if so anyone need a new Isis BB?
Posted : 04/08/2013 7:08 pm
Fitting spacers is correct with a 73mm BB in a 68mm shell. Make sure they're positioned correctly depending on if you have a BB mountedchain guide etc.
Posted : 04/08/2013 7:17 pm
No chain guide just a middleburn UNO chainset with a single sprocket on the rear which I can move in or out along the free hub with single speed spacers.
Posted : 04/08/2013 7:26 pm
As long as there is plenty of thread still going into the shell. Can't see it being a problem
Just don't put all spacers on the same side
Posted : 04/08/2013 9:46 pm
did they forget to include fitting instructions?
If it's HTII style then this should cover it
Posted : 04/08/2013 9:58 pm
 JoeG
As per the Hope link above, it should be 2 spacers on the drive side and 1 on the non-drive side.
But with ISIS, the non-drive side isn't flanged, so I don't think that you would be able to get a spacer on that side...
Posted : 05/08/2013 4:03 am
Just clean up the threads and return it.
Then threaten to set fire to the Superstar warehouse (Neil's bedroom).
Posted : 05/08/2013 4:10 am
As JoeG states
How do you space an ISIS BB?
The OP is clearly refering to an ISIS not HT2 BB.
Posted : 05/08/2013 5:14 am
yep missed the word Isis in there, didn't think anybody still ran the damm things
quick look suggests there is no 68mm one
http://superstar.tibolts.co.uk/product_info.php?cPath=23&products_id=31
Posted : 05/08/2013 5:18 am
The truvativ Isis bb used to have a flange on both cups , i forget they are not all like that
Posted : 05/08/2013 6:54 am
Good point about the non drive side not being flanged.... Cock I hadn't thought of that, this may somewhat throw a spanner in the works.... Any work arounds? Anyone want to swap a middleburn UNO set up for HTII??
Posted : 05/08/2013 7:46 am
