My Marathons have been on for about 3 years and are looking pretty worn, I really like the minimal punctures I've had but would consider something similar if anything else is as good. CRC have them on for £25 each all sizes, or maybe Conti GP4s for a tenner more, anything else to look at around £50 a pair?
Will be ridden on tarmac, gravel, cattle grids & cowshit. Rolling resistance not as important as puncture resistance.
My Conti Sport Contacts were pretty bombproof on a 24 mile a day towpath and cycle path commute. Haven't actually checked if they are still available as they don't need replacing yet.
Seems a good price for the value you've had.
My faves were Michelin Pro3 Endurance (think there is a Pro4 now), though I think they might be a bit more performance biased over reliability, I only had 1 puncture in a couple of years use.
I had the GP 4 seasons on my Pompetamine and suffered endless punctures. I think once the protective strip is pierced once it soon deteriorates. Replaced them with Marathon Plus's after recommendations on here and not one flat. Got them on the XLS now and so far they too have remained un-punctured.
They're a heavier tyre than the GP4's but once you're rolling that disappears.
I have a Marathon Plus up front on about its 3rd year and Vittoria Randonneur on the rear. The previous Randonneur lasted about 8-9 months before the puncture proof layer started showing but they were about a 1/3rd of the price of the Marathon plus.
They aren't as hard wearing but they are cheaper and seem to have similar puncture resistance - this is on roads and towpaths around Birmingham.
Same again, or Durano Plus if you want a little more speed for road duties. Both available in 28c. Have ridden Durano Plus on gravel ok, but it is really a road tyre. Has exactly the same puncture protection.
Marathons are a pretty good compromise between the bullet-proof Marathon Plus and the GP 4 Season. I've even taken to touring on them rather than put up with the (albeit infrequent) hassle of punctures. As a winter commuting tyre, I reckon they can't really be beaten.
I've just switched from Marathon Pluses to Durano Pluses and they seem like a pretty solid middle ground between puncture protection and a bit more pace/nicer feel.
craigxxl - MemberI had the GP 4 seasons on my Pompetamine and suffered endless punctures.
Same for me (even the bike model!) - I had been getting unacceptable amounts of punctures with GP4 season, and always on the back. I've replaced it with a Gatorskin which is holding fast for now, but it's fairly early days...
For balance, I use 4 Seasons and find them good - grippy, durable, very few punctures!
I've been using gp 4seasons for a good few years now after trying various tyres on my commuter. As above they work well for me but I do get the occasional puncture - usually glass. But very occasional.
= Marathons Or (marathon racers)
Will be ridden on tarmac, [s]gravel, cattle grids & cowshit[/s]. Rolling resistance is [s]not as[/s] important [s]as puncture resistance[/s]
= GP4
Marathons IMHO for what your doing will give you the best all round performance.
Personally is use Gator hardskins in summer and Top contacts in winter.
theflatboy - Member[i]craigxxl - Member
I had the GP 4 seasons on my Pompetamine and suffered endless punctures.[/i]
At least I gained mad speed skills in changing the tube considering it was an Alfine hub bike complete with full mudguards. The final straw was 3 punctures within 8 miles on the way out, another on the return journey and typically when it was raining much to my mates amusement. I thought I was going to end up running out of patches before I got home.
There's quite a big difference between the two, the marathon is around 750g, and the GP4 around 250g. Deffo try and find some middle ground.
I found the GP4 fine until i moved to London, then started getting punctures.
Now using some Halo Twin Rails 29mm tyres and they're holding up ok at the moment.
[quote=HoratioHufnagel ]There's quite a big difference between the two, the marathon is around 750g, and the GP4 around 250g. Deffo try and find some middle ground.
560g for a Marathon in 700x28C.
And £19.99 at CRC
I'm running specialized armadillo (elites?), for a 50km commute on the back end of no-where country roads covered in pot holes and cow shite for 9 months of the year. 1 puncture in 2 years - took me a while to remember how to get my alfine wheel off.
They are heavier and slower than the Pave I run the other 3 months of the year but it's not a fair comparison. Planning to fit more when these die.
I'm gonna say this, because I don't do it anymore, but in 3 years of commuting to and from London I got one puncture.
Generally get about 1 flat every 3000 miles or so, which I can cope with!
Used to run bontrager hard cases which were good
Now run some Specialized armadillos and found them to be good as well, maybe a touch better. It's only a hack/commuter bike but I love it
ah, i meant marathon plus
GP 4-seasons on my bike
Comparative test here if you like numbers (c. 2011) [url= http://www.conti-tyres.co.uk/conticycle/download_files/TyreTests/RoadBike_winter_test_02_11.pdf ]Test[/url]
Only available in 23, 25 and 28mm
Tread compound is good in low temperatures and the wet
My 2p-worth
Completely different tyres for different type of use.
I have GP4 seasons on my carbon road bike which have just done 10000k without a puncture and marathons on my commuter do it all bike which I'll expect similar reliability.
The marathons though are heavy to get going and dull to ride the contis are probably the best tyre I ever found but not for s daily use commuter.
Standard Marathons £16 per at Spa...
