5th Element Air Sho...
[Closed] 5th Element Air Shock. Service/repair
2 Users
 benz
As usual, thanks in advance for any guidance.
An older SC Superlight has a shock issue. 5th Element air shock which is 7.875" eye to eye and 2" stroke = 200mm x 51mm.
So, anywhere still likely to be able to service/repair?
Alternatively, any good vale replacement shocks to consider?
Thanks.
Posted : 09/07/2021 9:47 am
7.875" is 200mm, so there are options available for you for a replacement read shock:
https://www.chainreactioncycles.com/mtb/rear-shocks?f=4294965262
Forumite I_Ache used to service these apparently, I don't know much about where else you could try.
Posted : 09/07/2021 10:52 am
