5s (or narrow 6s) f...
[Closed] 5s (or narrow 6s) freewheel with a 12/13T smallest cog
5 Users
Looking for a cheapish (£15 max) 5 speed freewheel with a 12/13T smallest cog to go on my folding bike to get a higher top gear as at the moment spin out on the 14t cog. Chainring isn't easy or cheap to change as is a stuck 1 piece crank that'd gonna need to be ground/cut off to change. Spacing is too narrow to get anything more than a 5s freewheel in (maybe a 6s if narrow spacing).
Found a few 7/8s with 12/13t but way too wide to fit.
Any ideas?
Posted : 05/04/2019 3:00 pm
I assume this is screw on?
Pricey but comes in your desired size
Tenner, but you only get a 14t small sprocket
Posted : 05/04/2019 3:45 pm
Yeah, I've got the cheaper one already (or something very similar) and the 14T is just a little too spinny for 3 miles of canal tow path.
That expensive one - that's 2x what I paid for the bike!
Posted : 05/04/2019 4:21 pm
Got a 6 speed Suntour freewheel brand new still in box ,circa 1985, 13,14,15,16,17,18 !
Approx 30ish mm thick, any good or too close spacing ?
Posted : 05/04/2019 5:55 pm
Thanks for the offer but yeah it's probably a bit close spacing
Posted : 05/04/2019 10:10 pm
Freewheels went out 30 years ago, good luck.
Posted : 06/04/2019 1:57 am
Got a shimano 6 speed 13-18 or maybe a 13-21 freewheel good condition, any use?
Posted : 06/04/2019 3:24 am
Out of interest what is the hub spacing?
If it's ~120mm or wider you should be able to track down an older HG type cassette hub, if you don't mind building a wheel it should open up some cassette options...
Posted : 08/04/2019 9:47 am
The spacing is ~112mm and the 5s cassette fits but requires a little bit of levering (also got a 3mm spacer on the axle) - its a steel rear triangle so slightly spreadable, but it's 16inch wheels so very short stays to bend to 120mm.
Was thinking of getting a road hub ~130mm and seeing if I can swap the freehub for a ss/short one but that cheapest option for that is ~£120 so over 4x what I paid for this bike - I really only want to spend £15 max on this project as know the bike is likely to be stolen sooner or later as have to leave it locked outside an aldi overnight 2 nights a week! (been threatened with a £60 fine if bringing bike inside again)
Done the maths as really want to find a 12-21 or more but in no rush so gonna keep an eye on ebay
Posted : 08/04/2019 11:22 am
