Fairly flat, urban commute, no real option for cheeky trails. What do I [i]need[/i]?
Lights - Good ones. Seeing as I have it on my clipboard from another thread - http://www.stonehengecycles.com/product/9319/moon_xp500_shield_rear_light_set
Mudguards - Good ones! SKS Chromos are the pick.
Helmet - Up to you, but I would!
Rack and panniers - So much nicer than having stuff on your back.
Lock - Dependent on locations, a good lock is essential. Abus Granit or Krypto Evo and a front wheel cable.
Or, get a Brompton! 🙂
A bike with some lights, everything else is optional.
any bike would do.
what do you want?
my personal choice/ preference is a singlespeed roadie (pompino) 28c tyres, guards and a dynamo light.
I have the same, and I use the Kona Minute Cargo bike most of the time.
But I also do it on the full carbon road bike, or the Langster singlespeed too
TBH you could do it on a bmx, I just find the Cargo to be the nicest day to day, and the most use if I need to pick anything up on the way home
Traffic sense and patience. One of the best bits of advice I read was here at STW - try and avoid conflict.
My commute used to be 5 miles, I did it on a '93 Cindercone with mudguards, rack, panniers, and lots of lights. Don't get anything too fancy as a) it might get pinched and b) you want something heavy to make the 5 miles worthwhile! I used to carry way more than I needed in panniers just to make things a little more challenging 🙂
Get some mudguards, nothing worse than a wet ar$e when you get to work
I do 18 miles each way and prefer a sweaty back to a bike that handles like a pig. I have a rack and panniers. Hanging up in my garage. Try both and see what suits you.
Lights- and some back ups if you are commuting when its dark (I work shifts so a least one of my journeys is fully in the dark).
Might sound like I'm trolling but I think that some people go out expecting conflict and therefore find it (anyone that rides with a helmet cam to capture road rage for instance). I see more considerate driving than in considerate, and I believe in positive feedback not negative. If I see someone has waited for me to pass before pulling out/turning/opening door etc I'll give them a big wave and a thank you as I pass. If they cut it close what good does giving them the finger achieve, its going to make them more antagonistic towards cyclists not give them cause to calmly reflect on their driving.
2 tubes, good tyre levers, pump, small repair kit.
Multitool.
Spare lights - the little 2 LED ones are great. Aldi or EBC, about £4.00.
Headtorch.
Spare gloves & socks. Woolly hat.
Waterproof.
Jelly Babies.
crashtestmonkey - MemberI do 18 miles each way and prefer a sweaty back to a bike that handles like a pig. I have a rack and panniers. Hanging up in my garage. Try both and see what suits you.
Prefer panniers.
You can go shopping on the way home.
And I can't fit all the stuff I need for work into a comfy backpack.
sharp elbows and thunderous thighs.
mmmmm, thighs.
comfy shoes and a good bag? is the bike not more hassle than it's worth for 5 mins?
"I do 18 miles each way and prefer a sweaty back to a bike that handles like a pig"
you are doing it wrong.
i went out for 3 hours mtb on the way home last night with my lunch box and clothes for the day in my russian framefit bag - was grand
normally use a carradice as per stirlin crispin above
for 5 miles - id just use a bag. Mudguards are a must though - its no fun putting wet clothes on after and most of the time you get wet its wet from below spray than it is rain.
your doing it wrong.
you're spelling it wrong.
:tee hee:
A nice dutch roadster, lights, panniers and a good coat. Five flat miles is under the shower and change threshold.
A reliable bike - noting flashy (except the lights, ha!), just reliable and comfy. A 4 mile walk because your unloved chain exploded is a PITA.
Lights, many thereof. Good to have 2nd front and rear ones in case the main ones give up the ghost.
Mudguards. They reduce the misery of splashing through puddles of god-knows-what slightly more bearable.
Waterproofs if it's raining (or looks like it might). 5 miles might not be far in the grand scheme of things, but even if you're only out in the pissing rain for 20mins it's still nicer with a jacket/trousers that keep you dry, especially if you're not going flat out, so aren't going to get too sweaty. 🙂
Full TT machine, or track pursuit bike if its flat.
no need for mudguards if you're in a rubber aero suit.
drop a headset spacer a week untill you can fit your tt-ski's to your fork crowns, your back will get used to it.
18mm tubs @ 15 bar, disc wheels and a dinner plate chainring should see you nibbling at 7 minutes for the 5 mile trip.
don't forget to warm up and warm down on the rollers before and after.
jono
Good clothes, mudguards and lights.
Anything to minimise faff is a good thing IMO too. I.e. bolt up / non-QR hubs so you don't need a separate cable lock, lights that are permanently-attached and don't need removing every time you leave your bike unattended.
As others have said, I don't find panniers to be especially amazing. The extra weight over a rucksack is significant and for my 6 mile commute, having the weight over my shoulders isn't a problem. I actually use a pannier now - I bought it to see if I liked it and it's stayed on my bike mainly out of laziness TBH. YMMV
I was comparing a pannier set up with a bag pack. I hate the unbalanced feel- all the weight at the back of the bike, and usually to one side. A rack-top/saddle bag (carradice referred to and pictured) would put the weight on the centre line, and a frame bag like yours would fully centralise the weight. I reckon a frame bag would be ideal, but I can't grow the beard that goes with it.
and PMSL at jono.
Schwalbe Marathons or Marathon pluses too - they are VERY good tyres!
This is good advice.
breakfast.
post ride breakfast.
spare pants/socks left at work
I do a slightly shorter commute.
For a short commute like that, just wear your work clothes rather than messing about getting changed. Ride a bit slower on your way in to avoid sweatiness.
Bike: I've ridden everything from a cross bike to a cargo bike, via a MTB and a sit up and beg German bike. The cargo bike is the most sensible, the cross bike is fastest and fun.
Lights: Two front, two back. If one dies, the other will still work. I have a Cateye set, plus a cheap set from Aldi - the cheap ones just stay on the bike as it's left somewhere reasonable secure at work.
Bag: I've used a rucksack, a basket, panniers, courier bag. My favourite is a 'basket' on a frame-mounted front rack.
Helmet: I do, but mainly to stop my mother-in-law from nagging me.
Jacket: currently using a cheap Aldi one. Commuting ruins things, so go cheap, if possible.
Waterproof trousers: again, cheap Aldi.
Lock: heavy D-lock that lives at work at the moment, as I don't bother stopping on the way home.
I have had this - at least I had the rain kit. Missing links and a chain breaker are now in my commuting kit.
If you've an unlit stretch, a head torch (Alpkit gamma etc) makes puncture repair/tube swapping a bit easier, and can be an emergency front light or just provide extra visibility at junctions.
my helmet cam mostly captures other cyclists being dicks. ironic really.
its just there because that day you do get hit - youll find you go into shock IF your uninjured and forget to do key things - talking from experiance here.
Tools: I don't bother with any tools or anything. It's 3 or 4km, I'll get to work quicker if I either walk the rest of the way or head home and ride a different bike in.
For getting home, I have other options I can use, or just walk it pushing the bike.
Speaking of which: multiple bikes is useful. I generally don't have time (or energy) mid-week to repair things, so just ride a different bike until the weekend 🙂
