3x10 to 2x10 XT con...
[Closed] 3x10 to 2x10 XT conversion
7 Users
Looking to go 2x10 with my existing crankset and looking for a little advice.
40T or 38T ring to go with 24T and 36-11 cassette?
How difficult is it to set this up with the existing shifters and deraileurs?
Posted : 05/12/2012 7:52 pm
I'd go 40 if your ever doing roads etc to get to the trails.
Should have no issues setting it up, just adjust your front mech limits?
Posted : 05/12/2012 8:33 pm
The limit screw is all you need to do something about. I did exactly what you are doing but with an SLX crank set.
Posted : 05/12/2012 9:11 pm
I managed it and im a complete bike ludlite 🙂
I had 3 x 10 XT, bought a 2 X 10 chainset, and just adjusted the limit screw so it didnt try to shift too far. Works a treat 🙂
Posted : 05/12/2012 9:45 pm
I have a deore crankset, loped off the outside chain ring, swapped the middle one out for a bigger one (36 tooth) and wound in the limiter. No problems.
Posted : 05/12/2012 10:55 pm
Check for frame clearance around any pivots & Chain Stays. Previous threads showed a limit on Orange. There is one on Hecklers too.
Posted : 05/12/2012 10:58 pm
Have done this - just took the granny ring off and wound in the lower limit screw.
I think the chainline could be optimised a bit but not got round to fiddling with that yet.
Posted : 05/12/2012 11:01 pm
