Can you do this without the tabs fouling the chain? 32T doesn't work.
steve_b77 reckons 33T is the smallest you can go without the tabs fouling. ([url= http://singletrackmag.com/forum/topic/2x10-shimano-m785-cranks-whats-the-smallest-outer-ring-i-can-run ]here[/url]) Just wanted to make sure this is a dead cert before I press the buy button.
Cheers!
I have a single 30t outer on a Deore, I've no idea how different the Deore and xt offerings are in that respect
Cheers both.
Called round a few places for bolt spacers, no luck. Filed the tabs, offered it up, realised I'd have to file a whole lot more, went to the hardware store and picked up 10 for a quid.
Wife's Swift is now sub 25lbs with Rebas, flats and chubby ardents. And it's chuffing brilliant fun! Had to take it for a safety test, didn't I?
All the 30T and 32T (albeit NW) rings I've had have had the ring slightly offset to stop this happening. Spacers will do the same
