32t to 30t shorten ...
[Closed] 32t to 30t shorten chain?
8 Users
Do I need to shorten chain going 32 to 30 front ring?.
Posted : 21/10/2017 8:26 am
In theory you should, in practice probably not worth the bother.
Posted : 21/10/2017 8:47 am
Clutch mech? try it and see, should be fine.
Posted : 21/10/2017 8:50 am
If the chain is still taut when on the small sprocket then you're fine.
Posted : 21/10/2017 8:53 am
Depends, if your chain at the long or short end of what works on 32. I went 32->30 and left chain as it was, it was fine on both 32 or 30. When I fitted a new chain I went for a full link less, it was also fine. Might be a little short if I go back to 32 though.
Posted : 21/10/2017 8:55 am
I don't bother when I swap for 24hr events
Posted : 21/10/2017 9:20 am
The chain is going from wrapping around 16 teeth to 15 teeth - if it's slightly on the long side before then you can take out a full link (two teeth's worth). If it was already perfect then you can't take out a full link without ending up too short.
Posted : 21/10/2017 9:26 am
As above. On my bike, I can drop two and be okay, on the wife's bike, I'd need to shorten it (but she could go up two no bother).
Have a look at the chain length equation on the park website.
Posted : 21/10/2017 9:34 am
Cheers guys I'll leave as is and try it
Posted : 21/10/2017 9:57 am
