32 x 5mm foam rings...
[Closed] 32 x 5mm foam rings-from where?
5 Users
Just taken my old dt Swiss exm forks apart and one foam ring is tatty as!! Where can I get some for Wednesday?
Posted : 03/02/2020 9:23 pm
I need 2 lol not enough for the whole of stw
Posted : 03/02/2020 9:38 pm
And those are 32x10mm
Posted : 03/02/2020 9:39 pm
Q-Bikes on ebay - although their price will put the cost of a bag of 20 into perspective !
As the bulk bags usually work out less than a £1 for each foam ring I normally change them at each (RockShox) lower service rather than 'clean' the old ones.
Posted : 04/02/2020 10:17 am
As the bulk bags usually work out less than a £1 for each foam ring I normally change them at each (RockShox) lower service rather than ‘clean’ the old ones.
A LOT less than £1.... and since I'm a big believer in just keeping forks clean inside I tend to pull apart often .. clean then inspect seals and dust seals and stick in new foam rings... as i also buy 20x crush washers at once this costs me a few cc of lowers oil and a few pence in crush washers and foam rings
Posted : 04/02/2020 12:34 pm
@stevextc - where are the crush washers from please?
Posted : 04/02/2020 12:37 pm
A LOT less than £1 ???
90p isn't
Maybe cheaper somewhere else ?
But I like your prudency with crush washers! I tend to do those on an annual / 200 hour service as the manufacturers advice changed....will probably die soon 😉
Posted : 04/02/2020 1:11 pm
@iamnobody
Last lot were bought washers and retainers separate.... (just worked out that way)
ebay outdooroutlet £15 for 50 retainers but now in pairs only ??? (I always find this sort of thing tends to be ephemeral and you need to search each time)
Now quick look shows
https://www.ebay.co.uk/itm/RockShox-Metal-crush-washer-retainer-8mm-bulk50/113764000408?hash=item1a7cdce298:g:oF0AAOSwv-lc7TEG
The washers I'd bought earlier ... can't see immediately but probably as easy to just search
Found these quickly...might not be the best price but ...
https://www.ebay.co.uk/itm/8mm-50-Piece-Rockshox-Crush-Washer-Set-Pieces-8mm-114015259000/132734820437?epid=2256068373&hash=item1ee79ca055:g:NEkAAOSwIrBbabUc
Posted : 04/02/2020 1:18 pm
Crush washers only crush once .
Posted : 08/02/2020 8:38 am
The wink was especially for you !
Posted : 08/02/2020 4:04 pm
