Does anyone make a 32 tooth NW oval ring that's NOT threaded and without built in spacers. I've got a 34 absolute black without this but the 32 comes threaded and with spacers so doesn't fit my cranks. Cheers
If 104bcd I thought the spacers were a necessity as the chain needs to go where the bolt heads would be without the spacers?
Could you not drill and file? I thought the above were essential with certain BCD otherwise the chain won't be allowed to wrap round the ring properly.
Would your cranks take a direct mount?
why doesn't it fit your cranks?
Doh, that's what I should have asked ^
My cranks are 10 speed xtr (985? )so the bolt heads are on the inside which is where the rings thread is. With the spacer as well it means the bolt aren't long enough to do up. I've tried finding some longer bolts without success.
