Any recommendations for the above chainring replacement?
For Sram X1 Cranks. Non boost. Currently have a 94BCD spider but direct mount is fine.
Thanks!
SRAM X-SYNC steel - £17 and will outlast any alloy ring, with no more weight gain than a big bag of crisps.
I’m using a burgtec direct mount. It works its purple , not much else to it.
Thanks.
Also if anyone knows what offset I would need for non boost cranks that would be great. Its for a 2015 Whyte T-130 if that helps.
+1 for the steel x-sync rings. If your cranks have a non boost spider then I think that the ring will be fine fitted to that.
+1 for the steel. Solid!
