32 hole hubs can i ...
[Closed] 32 hole hubs can i use 24 hole rims
8 Users
 elma
Just an idle thought i've got some hope hubs lying around that i'd like to use on some road rims i have will this work or will i die a horrible death.
I know i could of googled this but the answers are better here.
Posted : 07/06/2012 9:31 pm
Just drill 8 more holes in the rim.
Posted : 07/06/2012 9:33 pm
You could - but you will need loads of different length spokes and it will be very tricky to get tension right
Posted : 07/06/2012 9:34 pm
feeling brave?
http://sheldonbrown.com/mismatch/
Posted : 07/06/2012 9:36 pm
Ive got a 32h Campy hub laced into a 24h rim. Just did 16 on the drive side (3x) and 8 on the non-drive (1x), its been fine for a few years now. Make sure you check and re-check the lengths. I found stronger/stiffer spokes as you only have half the amount on one side.
Posted : 07/06/2012 9:42 pm
No, you only need one length on each side, but your right about the tensions.
Posted : 07/06/2012 9:44 pm
you just miss out 1 in 3 flange holes.
It's no trickier getting tension right than with a 24H hub, but it does need to be pretty high.
I'd flog the hubs or rims and do it right, unless you will have them a long time - they'll be worth...not much.
Posted : 07/06/2012 9:46 pm
I think Matt from 18 bikes has done it. From what he'd said, I don't think he'd want to do it again.
Posted : 07/06/2012 9:47 pm
I've messed about with stuff like this, like I say, it needn't be that complex.
Posted : 07/06/2012 9:50 pm
Ask my m8 http://www.custom-wheels.co.uk he will tell you all you need
Posted : 07/06/2012 10:21 pm
