30t n/w ring on 104...
[Closed] 30t n/w ring on 104 bcd cranks
11 Users
a mate of mine wants to go single ring up front so i've recommended he switch the 38/26 rings he currently has to either a 32/34t ring
he asked if he can get a 30t on there but i'm not sure if it will work
his cranks are shimano deores (dual ring setup) so they're 104 bcd
but i suspect a 30t ring may not fit due to the size of the ring
can anyone clarify/confirm this please?
Posted : 18/05/2016 9:48 am
Will be fine. The 30t rings are offset slightly to allow chain clearance on the spider. The female part of the bolt is built into this offset part.
Posted : 18/05/2016 9:49 am
 LAT
They do fit. The nuts are machined into the ring to save the space needed for separate nuts.
Posted : 18/05/2016 9:50 am
I was running a 30T on my 104BCD XT cranks without issue. The smaller rings normally have a thread for the chain ring bolt to screw directly into so you don't need the 2-piece bolts.
Posted : 18/05/2016 9:51 am
I'm running a 30T NW ring on 104BCD - the ring has tabs to keep it away from the crank arms. The bolt holes in the ring are threaded so you'll need bolts to fit.
i suspected that there would be chain clearance issues but what you've all said seems to make sense
thanks for the info folks.
Posted : 18/05/2016 10:02 am
32t oval betterer. Should also be threaded.
[url= http://www.superstarcomponents.com/en/i-o-chainring-narrow-wide-style.htm ]Superstar do a 30t 104bcd. [/url]
Posted : 18/05/2016 10:08 am
+1 will work fine
+1 oval betterer.
Posted : 18/05/2016 10:29 am
30T Hope ring on previous generation XT cranks here.
The ring is slightly offset to allow chain clearance, so it'll fit.
Posted : 18/05/2016 10:41 am
+1 will work fine
+1 oval betterer.
+1 for both...
Posted : 18/05/2016 11:19 am
+1 will work fine
+ another 1
Superstar 30t and uberbike 30t both working fine on 104 cranks
+1 oval betterer.
Well, yes maybe/maybe not. 32t is the smallest oval that you can fit on a 104BCD crank. With this, you're effectively turning a 30t during the dead-spots and a 34t during the power bit.
I found that the "34t effective" bit was just too much with a 11-40 and I'd be off and pushing too often. Swapped to a 30t round and that's seams better for me.
I do have a direct mount 30t oval on another bike, with a SRAM crankset. That's working really well with 10-42.
When the big XT cassettes finally land (is it 11-46?) then a 32t oval will probably be spot-on.
Posted : 18/05/2016 11:52 am
