I've been doing some looking for adaptors to be able to use shimano cranks on a bike with PF30.
The adaptor cant have a wide flange as the BB shell is already 92mm. Can't see any like that but has anyone know of any that might fit.
Looking at this as a cheaper option (got a spare shimano crankset) to replacing the 30mm turbine cranks on my bike as the crank arm / chainring interface is buggered on the crank
Thanks
Wheels Manufacturing- available through Madison/Freewheel or your local shop have lots of solutions including a threaded replacement for PF30 which I have used successfully- initially expensive but then you can just replace the bearings. I think Kinetic Bike Bearings did some adaptors as a cheaper, temporary replacement too.
I use these, and was expecting them to wear out fairly quickly.
However, they've been spinning happily away in my fatbike for three years now.
I’ve used the raceface top hat adaptors with no issues.
How did you screw the interface?
