Hi all
Im looking to upgrade my Merida Sculptura 905
im looking to get decent value for money and have narrowed it down to either a sensa Giulia or a Dolan Tuono (both 11s UDi2)
any other VFM options/recommendations ?
Dolan's ride well.. and I have loved racing on DI2 both on and off road
I assume this is for racing at a decent level?
Canyon Ultimate CF SLX in that case.
If not £3k and some shopping around will get you a handbuilt Stainless steel or TI bike.
Dolan Ares SL?
Ridley Excalibur Di2 £1999 at Pearson's
http://www.pearsoncycles.co.uk/store/content/106/Ridley-Excalibur/
I've a couple of Ridley's and they ride very well.
Does VFM incorporate ride quality that you like, or fit?
Or is it just spec for the money?
If i had £3k i would be looking at something like a Stoemper Taylor ENVE fork, and then campag neutron wheels and probably end up with Campagnolo Veloce group set....
Really depends what your idea of VFM is really.
cheers peeps, ill take a look at those recommendations
yes its primary use will be racing (though not a decent level)and sportives but with speed/climbing taking priority over comfort
ride / quality and fit will be my secondary considerations. so i just want to focus on the spec for money for the moment
i had discounted the canyon as they don't do a CF with di2 and the SLX is a bit pricey, i figure i can get a better spec with a better £/lbs
Defo the Canyon Ultimate CF SLX 7 - Ive got one therefore its the best etc. Seriously I've got the current one, £2800 and its bloody great. Full Ultegra and Kysyrium SLRs for that money, and a frame that weighs 780grams...Im 14 stone and it is really solid under sprinting, but verrry comfy as well on the crappy winter tarmac/potholes.
The SLX 7 looks great.. If I wasn't supported by another great manufacturer I'd be tempted.. and on that note, Try a new Kinesis Aithein with Ultegra 11spd and wheels?
[i]ride / quality and fit will be my secondary considerations[/i]
Not trying to start the usual stw row but are you sure you've got your priorities right here?
If you are serious about racing, I'd consider the possibility of crashes and crash damage. UDi2 might be a bit pricey to replace.
If it was my money, I'd go for something that cost £2000, with cable Ultegra, and spend the rest on a bog standard wet weather bike.
ok ok ill take another look at the canyons
ride / quality and fit will be my secondary considerationsNot trying to start the usual stw row but are you sure you've got your priorities right here?
i will take those into serious consideration but im just drawing up my shortlist based on VFM first
Crikey, i take your point but im happy to take the hit if i do topple, and i already have a winter bike
Something from Rose bikes?
Planet X N2A looks good, again, I'd err on the side of less super bling and more tool for the job. Hopefully it'll be chucked in and out of cars and vans and ridden like it doesn't matter. There's a lot to be said for buying a bike that you really, really want to ride every time you look at it, but a good race bike should only be a means to an end...
looks great but im looking for 11sp di2 (i have the 10 already)
Dolan Ares SL?
comes in at a tad more than the SLX which i prefer
Stoemper Taylor
not what im after at this point but certainly on the N+1 list
not ruled out but read some negative comments and i cant figure out their line up, can anyone explain it ?
Planet X N2A
not Di2 (but maybe worth a call)
no weight specified, looks a bit aero/heavy ?
A few pounds either way isn't going to make any difference at all, and you can't buy a bike that will make you quicker or a better climber...
i must disagree, i am noticeably quicker on climbs on my 905 than my Btwin (winter bike) which is around 1,5kg heaver, and im also noticeably quicker on my XC 29er whippet than my 26 mid travel
I'm trying to suggest that by upgrading something that's already decent won't give you much in the way of benefit.
yes that's a fair point, one of the main reasons i want to change is im dropping a frame size, i had an accident a few years back which left me a little less flexible but now im much better, so whilst im changing bikes i do want to feel like im upgrading a little but dont really expect(but i do hope) to see any big performance improvement from my 905 to ?????
I kind of learned my lesson after a similar pursuit; buying lighter and lighter bits, trying to put the best bike together that I could, then getting roundly hammered by people riding bikes that weighed more than my winter trainer. I began to get decent when I stopped worrying about the bike and started seeing it as a tool to get the job done. A bit like using a hammer; if it hammers, the best way to improve your hammering is to get better at hammering, not buy a 'better' hammer.
Then I took up rambling, as you can see!
How much wind tunnel testing has the Planet-X gone through?
The Merida seems like a reasonable bike. You won't see much of an improvement in performance from your current bike to the bikes you are looking at. Probably only some very serious training, lots of racing and weight loss (you not bike) will see big performance improvements.
