3 Peaks Challenge o...
[Closed] 3 Peaks Challenge on an MTB
6 Users
A friend wants to do the above, has asked me for info/suggestions. Is this do-able, allowed, are there set trails/routes etc. etc??? Apologies for possibly stoooopid questions, but thought I'd check with the STW font of knowledge? Cheers
Posted : 28/06/2016 12:06 pm
The 3 peaks CX race uses sections that are only open on race day, one or two bits aren't even footpaths. The only one of the three with a legal BW to the summit is Ingleborough and is pretty full on (the race doesn't go that way BTW).
There are a limited number of paths/tracks on to the three summits and now that summer's here (I can tell - the rain is warmer) these will be packed with walkers between the hours of 10am to 6pm.
Posted : 28/06/2016 12:14 pm
Presuming you are on about the national 3 peaks challenge?
Almost impossible during summer due to the tourist footfall. I've done it before and I'm supporting another team doing it in August. If you were doing it on a bike you would have to do a different route down most of the mountains than the normal walking route as it's just not suited to bikes. You would end up carrying more than riding.
Posted : 28/06/2016 12:24 pm
Ah, being in Mordor, I assumed the OP meant the Yorkshire 3 peaks.
Posted : 28/06/2016 12:31 pm
If he means the national one, surely a road bike would make more sense. Unless they are planning the driving challenge, in which case a read of this may be helpful:
https://www.thebmc.co.uk/three-peaks-challenge
Posted : 28/06/2016 12:37 pm
Would be a miserable experience on the national 3 peaks. You might as well do it carrying a fridge. Scafell Pike does not have a BW, which is scarcely relevant as you would be pushing in both direction for most of the up and a fair bit of the down and along. Snowdon would most likely be a pain in the arse due to the voluntary ban hours.
No guarantee of peace either! I was up there 6:30am last Sat - there were well over a hundred people around the top from a couple of big events 😯
Posted : 28/06/2016 12:57 pm
