Looking at swapping my 3x9 to either of the above. Which would people recommend and why?
Are you strong enough to ride within the range of 1x10 everywhere you ride?
I went from 3x9 to 1x10. The triple had a 32t middle ring with 34 being the largest on the rear. I spent a month or so just using the middle ring, reasoning that if I could manage 32 front and 34 rear, then going to 10 speed rear 36 would be fine. Not very scientific I know, but at least you will know if 1x10 is suitable for you.
^ that's what I did but was on 2 x 10 and wanted to see if I could do 1 x 10. I had 28/40T chainrings and a 34 cassette. All was good so went for a 30T ring and 11/36 cassette..
2x10 if you're not sure tbh, it should be the default option for most people. But as above, you can test it out with your existing kit, just ride within the gears you'll have with 1x10 and see how it works out.
I was doing a race last year, which had a long and just slightly unpleasantly steep climb between stages- the number of people on 1x10 pushing up it was crazy, it just took a couple of extra degrees to have them all off and broken. So do plan for the big rides not just the everyday rides!
I've recently gone from 3x9 11/28 to 1x10 36-11/36, and i'm very pleased with it (on a 26er hardtail). Have a good look at the Sheldon Brown gear calculator before deciding. The 1x10 change only meant loosing 1 or 2 of the very lowest and highest gears, and there's more than enough for climbing anything. It will depend on your normal use of gears with the current 3x9. If you use the middle ring lots, and prefer a higher cadence or spinning up hills slowly, then 2x10 might be better. The 3x crank will be perfect spacing for 1x10 on the middle position, saving you a new crankset. Either way, having a clutch mech with 10 speed makes your drivetrain a lot quieter too.
Went from 3x9 to 2x10. Got XT cranks and rear mech.
After a while I had a week of getting chain suck on my 28t and also the chain kept dropping off on jumps so I got a 30t narrow/wide and replaced the two rings. Its hard work sometimes but I either sweat more and suffer or get off an push (might get a hope t-rex though) Worth it for the simplicity and not having to care about a front gearing system, but maybe you just do what I did. Didn't cost a massive amount.
2x10 is much more better I think, it´s more dynamic! đŸ˜‰
Just switched from 2x10 to 1x10 as I rarely use the very lowest gears anyway.
The trigger was crashing a chainring on a rock so I took the opportunity to get a Wolf tooth Drop Stop N/W 36t. Free postage from the States was a sweetener but I didn't have much choice as this was the only ring I could find that was compatible with my cranks.
Not ridden any big hills yet though, I'll let you know how I get on.
Had all three on my last bike, I've stuck with a 1x10 with an expander ring on my new one. I'd be tempted to drop from a 34t chainring, but otherwise it feels secure and right having only one gear changer to use. Leaves an ideal space for a dropper post lever too...
Seeing as no-one else has said it - go 1x11
The shifting is awesome, it removes the gearing issues of 1x10, and now X1 is out the entry cost has come down dramatically.
2x10. Why limit your gears for a weight saving you'll never notice?
do you ride hills? or mountains?
would like to go 1x10, but i'd either be spinning out on the flat or busting my knees on the climbs...
I'm thinking 2x10 is going to be the way for me to go so I've got a few more gears. Now to decide which brands to go for
Do you like gaps in the gears? You can have sweeter changing with more up front. 1t gaps are nicer IMHO
