2x10 deraileur ques...
[Closed] 2x10 deraileur question
4 Users
I am 'updating' my old bike for my son. It is currently 3x10 but i picked up some 2x10 cranks and shifters for it. Will the 3x10 front deraileur i have work fine on the 2x10 set up or should i order a 2x10 specific one?
Posted : 21/01/2019 3:38 pm
The 3x10 will work. Just use the limit screws to stop it going in to the 3rd position.
Posted : 21/01/2019 3:45 pm
Great. Saves me a few quid.
Posted : 21/01/2019 3:47 pm
Correct. Will work.
Posted : 21/01/2019 6:42 pm
Usually.
If the derailleur, crank and shifter are all 3x then the limit screws will let you lock it down to 2x travel.
If the crank is a true double and shifter 3x (and you're exceptionally picky) you may find it doesn't quite shift properly - a bit like tension never being quite right. Offsets and pull are the problem. The 2x/3x switch you used to get on Shimano left pods fixes it if available.
Usually it's not a problem but there are combinations that can be annoying.
Posted : 21/01/2019 6:51 pm
